Getting clay mud off tires easily
   / Getting clay mud off tires easily #61
I just let it dry and it will fall off next time I drive it.
Sweeping up is easier than trying to get the wet mud off.
   / Getting clay mud off tires easily #63
What is a solution for sticky, clay-mud build-up on tractor tires and skid steer tracks when I get back at the shop? From Oct-Mar it doesn't take much for the sticky clay to create a 1-2" layer all the way around the tires/tracks.
Short of pressure washing before going inside, is there a labor-saving way to get the bulk of that mud off before going indoors or near the shop.
Is there some type of "cattle-guard" that you could drive over that would get it off?
How about some sort of tire-scraping wheel or track attachment?
Maybe something you can put on the tire as a non-stick treatment?
Something else?
Thanks, Scott
NO. Pressure wash.
   / Getting clay mud off tires easily #64
In the dirtbike world we use Armor-All on the tires. Armor-All would wet their pants if they heard me say that because there have been many streetbike accidents where Armor-All was made to make the tires pretty... and slick. Armor-All between pavement and rubber is as bad as wet ice.
As others have observed no treatment lasts long. But I think Armor-All is kinder to tire rubber than brake fluid or Liquid Wrench.
   / Getting clay mud off tires easily #65
Seeing the topic all I could think was My Cousin Vinny......"You got mud in your tires".
   / Getting clay mud off tires easily #66
I googled it. Seems spraying a clean tire with liquid wrench will inhibit the clay from sticking. Makes sense that any kind of spray lubricant might do the same. I have run the tires through the sandy bottoms to peel off the mud bud our clay is not the worst kind.
Liquid Wrench is toxic for the environment----don't spread it on your property
   / Getting clay mud off tires easily #67
Something else?
Thanks, Scott
I live in an area of black river region mud. The "easiest" way is to let it dry and take a big hammer to the tires. The mud will 90% crack off then do the pressure washer. Almost nothing will get this stuff from between disk harrow blades except the above method. Wish I had a better answer for you.
   / Getting clay mud off tires easily #68
Years ago touring the JD Tractor Assembly Plant I noticed the tractors going to Europe had different tires, especially the rears. They had a flatter profile across the treads. They also looked a little wider but the flatter square-corner profile may give the illusion of being wider.
i never thought much about the reason for the distinct design difference. Reading this thread gives me the idea it might be related to climate and soil conditions in Europe. Just a thought.
   / Getting clay mud off tires easily #69
Would a truck "wheel wash" do the job?
Most quarries and sand pits use them.
   / Getting clay mud off tires easily #70
I just built a new shop and put a cement pad off to the side. I have a pressure washer right inside the door and it gets used to clean up the tractor prior to coming inside. Even with that I still have some mud that is difficult to remove and it falls off inside.
Luckily I put a drainage trench down the middle of the parking spot. Sweep the dirt into the drain trench then about every six months I remove the grates and wash out the trench. The drain goes into a dry well I installed for this purpose.
So far works for me. I agree the best way is to avoid working in the mud. However in my case I am frequently working around the periphery of a pond so its unavoidable.
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2212 (A58376)
2212 (A58376)
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
1996 Berco DY350A Vertical Honing Machine (A59213)
1996 Berco DY350A...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
8' Avalanche Snowbox (A55272)
8' Avalanche...
