Getting clay mud off tires easily
   / Getting clay mud off tires easily #32
For those of you with the pressure washer solution - what is about the minimum pressure washer specs you might recommend for tires about the size of 14.9-28?
Do you think a little 2,000 psi/2GPM would suffice for sticky clay?
I realize that more pressure and volume would do it faster, but I'm not cleaning concrete.
   / Getting clay mud off tires easily #33
My simply solution to not get mud on tractor tires is to stay off the tractor when it is muddy. When you drive a heavy tractor over ground that will turn to mud and stick to your tires, your leave behind earth that is like concrete. So what did you accomplish except make extra work for yourself and shorten the life of equipment.
I guess I’ll just sell my skid steer and tell my construction guys they’ll have to carry the building materials by hand until summer.
   / Getting clay mud off tires easily #34
My tractors I store in a shed with #57 gravel. I don't care if mud gets on tires or gravel and horses poop in there anyway. I have a nice new asphalt driveway also but by the time I drive around, through a pasture and down the road wide open the driveway stays clean.
Lots of time they'll be mud on our paved road but after rain it's washed off.
   / Getting clay mud off tires easily #35
A 2000 psi washer would work but it would take awhile to clean a tire that size. Using a Rotox nozzle would help.
I use a 3500 psi model without a Rotox and it works ok on my 12.4-24 tires.
   / Getting clay mud off tires easily #36
   / Getting clay mud off tires easily #37
I drive down our road (gravel) in transport gear. But you gotta watch out as sometimes those chunks will come flying right at you
   / Getting clay mud off tires easily #38
What is a solution for sticky, clay-mud build-up on tractor tires and skid steer tracks when I get back at the shop? From Oct-Mar it doesn't take much for the sticky clay to create a 1-2" layer all the way around the tires/tracks.
Short of pressure washing before going inside, is there a labor-saving way to get the bulk of that mud off before going indoors or near the shop.
Is there some type of "cattle-guard" that you could drive over that would get it off?
How about some sort of tire-scraping wheel or track attachment?
Maybe something you can put on the tire as a non-stick treatment?
Something else?
Thanks, Scott
Old, used tooth brush. Maybe a little soap if you have it.
   / Getting clay mud off tires easily #39
I heard there were a lot of guys looking for work. Give the new guy the toothbrush.
   / Getting clay mud off tires easily #40
Better first find out if he charges by the hour or tire. If by the hour or tire, cleaning with a toothbrush is going to take a long-long-long time.
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59575)
2018 INTERNATIONAL...
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
John Deere 980 Field Cultivator (A59814)
John Deere 980...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
