Getting back into hay
/ Getting back into hay #41
I’m going to use a range finder to get a little better idea of the size and I’ll report back.
Use this site for acreage, soil types, and other useful information
/ Getting back into hay #42
Hope you dont need to put down any fertilizer in those fields….
Yeah, it will never pay to fertilize that field for hay. It may be worth a round or two of crushed limestone instead. A soil test as someone said is probably a good idea.
/ Getting back into hay #43
Cut and baled first cutting a couple weeks ago. Just a small field, probably an acre or maybe a acre and a half. Starting back with hay so that my kids can help and learn hard work, working on equipment, how things don’t always go to plan, etc. The kids are still young so I’m going to ramp up over the next 2-3 years and shoot to bale about 20 acres, all small squares. Other than the tractor my equipment is all old but fairly reliable and I’m sure will give some good lessons when it breaks down. First cutting was 96 small squares which is about the average the previous guy was getting when he baled it for me. Need to do a soil test and add the correct fertilizer mix. Here’s a YouTube video I put together of the old equipment at work.
So cool. You'll create some memories for sure. The big thing in Oregon right now for horses is Teff. Has about 7.2% sugar. Yes, horses are becoming pre-diabetic as well as humans.
/ Getting back into hay #44
Just fertilized for the second time this year 21-0-21 was $ 814.00 per ton , bright side is after I spread it yesterday we got about 1/4" of rain to soak it in last night, so I am thankful, the only thing I have left to do is put out some herbicide to kill some vasie grass and native crabgrass that I see has popped up.
I am in East Texas and Vasseygrass is about to take over my pasture. What herbicide are you using to kill it?
/ Getting back into hay #45
I was amazed at the aging equipment you have in apparent usable condition! Warms the "get by with what we got" heart! It doesn't sound like you are in the high volume hay-as-a-cash-crop business and (thinking I have a pretty clear vision of your circumstance,) why do you bother to use that hay conditioner? Most people in that era used the conditioner ONLY if they had a hurried need to take up the hay a day before it would otherwise have dried. Maybe that hurry is "you" these days with so much going on, but unless you need to expedite things by a day it is wasting a lot of man and machine time IMO. Many in that era used a hay tedder between cutting and raking. The tedder does double duty in that it worked if you had an unfortunate rain too.
/ Getting back into hay #46
The best thing I have found is Pastora, or I use a 10' weed wick with a 50% roundup 50% water mix and when the vasie grass gets up above the hay grass enough that the wick won't drape on the grass I drag the wick across it and that's all it needs within 2 weeks it's smoked, the problem with just about any herbicide for vasie grass is it stunt's your hay grass growth for a couple of weeks, the weed wick won't. I may start spraying a pre-emergence after I cut next time to see if that helps.
/ Getting back into hay #47
That's awesome. I just started getting into it and bought, what appears to be the same sickle mower you have. I bought a JD 37 sickle mower. I don't have rear hydro ports so I ran the two hydraulic lines to my bucket and borrowed 2. The sickle mower blew out the hydraulic cylinder so a farmer up the street helped me replace that. Then the brush guard snapped off so I had to disassemble the pitman arm to clean out all the grass and then take the guard to a welder to fix it correctly. As you say, things will break down and it's been good learning how to put it all back together. I did my soil test last year, added pelletized lime and 19-19-19 and the field is coming on strong.
/ Getting back into hay #48
Can you clarify a little bit? "50% Roundup" might mean several things. Roundup as sold in the stores ready to spray is 0.96% glyphosate. The glyphosate concentrate sold many places (like Tractor Supply, etc.) is typically 41% glyphosate. Pretty well any likely mix chosen is going to kill the grass too, except that wicking it on (with the undesired stuff being high) may preserve some of the grass.
/ Getting back into hay #49
Okay I take full strength glyophospate Roundup or generic I believe that is 41% and I put 1 gallon of it in the wick and then I add 1 gallon of water, at that point I have what I call a 50/50 mix, if you wait until the vasie grass is about 1 foot taller than your haygrass and with the weed wick attached to your frontend loader so you can raise and lower it accordingly to just drape across the vassie grass you will kill it dead and will not kill one blade of your haygrass, you aren't spraying it just wetting the tall shoots of vassie with the mix, it's a flawless operation.
/ Getting back into hay #50
OK, I understand. That means you are using 20.5% glyphosate mixture which is more than twice the highest concentration recommended by the USDA for ANY killing application ! Man that is STRONG !! Besides that, the price of 41% glyphosate at TSC went from $54 for 2.5 gal last year to just over $135 this year. That means at current prices (well last week, may be far higher now...) you are putting $50 worth of glyphosate in your rig...? Somehow I doubt it , but I'll take your word for it.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
Honda UTV (A56859)
Honda UTV (A56859)
24220 (A56859)
24220 (A56859)
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
