Getting a whole house genny installed...
   / Getting a whole house genny installed... #111
There's nothing wrong with exercising your generator by killing the main breaker and simulating an outage. If it gives you peace of mind or if you learn something along the way, all the better.
Mine goes through a 20 minute exercise every week.
   / Getting a whole house genny installed... #112
They all have a power on self-test procedure, but I meant a true, shut down your utility power for 24 hours kind of exercise
   / Getting a whole house genny installed... #113
Here that happens at least once a year.:laughing:
   / Getting a whole house genny installed... #114
I put a 20kw B/S with the 10 year parts/labor/service call warranty, 200A outdoor meter head transfer switch, 75' of wire run to generator unit (keeps the noise way down), 500 gallon propane tank installed (future rental cost is $36 a year), all piping, regulators, filled tank, and 2 load shedding switching with everything installed - 8K. Only thing I did was poured a pad for the generator and dug the trench for the wire from the unit to the transfer switch on the house.
   / Getting a whole house genny installed... #115
We have a diesel yanmar unit 12 KW to power our home. It runs the air cond, the well, kitchen, master br and security system.
It runs at 1800 rpm and is very quiet, its both 3 phase and single phase. It will run all day on about 3 gallons of diesel. The electrician charged us about 1200 to wire it up properly. I already had the transfer switch.
Im happy with it and that's all that matters...:D
   / Getting a whole house genny installed... #116
What did the genny cost you?
You know, I really like Yanmar engines...and I've thought about finding an older Deere or Yanmar compact, pull the engine (and the PTO gearing) and get a generator head.
I'm probably not skilled enough, but that would be one way to get a powerful (18kW to 20kW) diesel generator at a fairly reasonable cost.
   / Getting a whole house genny installed... #117
Roy if you do that... I want to see the DIY thread. Sounds like a great project!
   / Getting a whole house genny installed... #118
My 20kw Generac running on NG cost about $5,500 total. I see prices vary widely depending on where you live.
   / Getting a whole house genny installed... #119
They really do - there also is a LOT of variance in how it is installed. Concrete pad vs plastic, distance to transfer switch, type of transfer switch, did you need a tank installed and filled, length of piping to gas source, did you use risers or just cap the line in, load shedding switches used, etc.....
   / Getting a whole house genny installed... #120
Nice job on the wiring, very clean.
I believe you said you install Generac.. If so, do you know what a close color match is for the enclosure of the Guardian generator? I just had a 22KW unit installed and the monkey's nicked the paint unbolting the unit from the crate. I'd prefer to get a rattle can if I could, I don't really care to deal with these people if I don't have to.
The manual says what kind of oil to use, but no mention of a # for the filters. They have maintenance kits but these are generally a bit more expensive.
Is there an awesome forum like TBN where people discuss all things generator?
Thanks!
not all generators are easy to install. i did this one yesterday and it was a pain. problem was he had a 400 amp service and only wanted one side controlled, but he also had a well control he wanted added. in order to add 20 amp well to a 200 amp service i not only had to add a transfer switch, but had to add a 200 amp feed thru panel so i could add the well. then i had to add a gutter ( j box) and reroute the feed to the house.made for a cluttered install but i can see no other way to do it. The inspector loved it. Original panel are first 2 pictures. If you notice all the writing, the original owner had a suicide manual transfer system installed.....no interlocks.
View attachment 477212 View attachment 477213
These are install pics
View attachment 477214 View attachment 477215 View attachment 477216
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Kubota RTV 900 4x4 (Diesel) (A54865)
Kubota RTV 900 4x4...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2011 Western Star Trucks 4900 Tri Axle Truck, VIN # 5KJNALDR4BPBA7822 (A54865)
2011 Western Star...
