Traction Get stuck in mud easily
   / Get stuck in mud easily #1
terencesprague
ford 1520
When the ground is pretty wet from rain my Ford 1520 gets stuck easily when mowing. It's a 2wd with turf tires. I am planning on switching the back tires to get more clearance to put on the chains I bought for it. Should I get liquid ballast such as calcium chloride - will that help prevent getting stuck?
   / Get stuck in mud easily #2
Chains might help keep you moving, but you might tear up your lawn. Filling those tires will help a little. But it's best to stay off wet grass...anyway, wet grass doesn't mow too good.
   / Get stuck in mud easily #3
Take it easy,the last thing you want breaking traction...could end up damages or more.
   / Get stuck in mud easily #4
It's the way things are.
Wet = slippery = less traction.
2wd = less traction
turf tires = less traction
chains = tear up ground = dig hole when lose traction
rib tread on tire = better traction = damage turf = dig hole fast when lose traction
4wd = best traction, chose tire to meet needs
Front End Loader = way to extricate stuck tractor (usually) without 2nd vehicle
filled tires = heavier vehicle = marginally better traction, all options above still apply
calcium chloride = badly rusted rims in time = expensive if you keep tractor that long
2022 FORD F-250 (A58214)
2022 FORD F-250...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
