sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,862
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Over the years, I've seen many thread questions on how to build a stone boat and what they look like. That's how you get rocks out of fields the easy way. These are off the 'net and if you don't know how a stone boat looks, here they are. I'm no expert but picked lots in the glacial till of northern New England. No more.
Above is a picture of the front half a stone boat. Note the turned up steel end to slide better and keep from digging in. Heavy steel with holes to bolt 2" planks to. Hardwood best and note the cross bracing. It's usually 2" planks and hardwood like maple or oak preferred. Use carriage bolts or the bolt heads dig in and catch on things.
Above is a closeup of that turned up front that's commercially made. It better be rugged with a strong point to hook up the chain. Ir's easy to make one if you have a shop bend the steel plate. Just do it right or fail under hard use.
Here's a beautifully made commercial version and looks the same as the one above. At this length no cross piece is needed but a six or seven footer would need a 2X piece of wood for bracing support and to keep rocks from sliding off. Also put a 2X at the tail end. I can't recall a stone boat longer than maybe 7 or 8 foot and most were maybe 6 foot. Rocks are heavy and really offer sliding resistance when pulling.
I've seen a couple like these over the years but mostly for lesser use and smaller rocks since you have to lift them on. For just a few rocks, old car hoods work as does anything that pulls and slides. We finally switched to loader, a dump truck and four boys to pick.
