generator to home panel connection
   / generator to home panel connection #71
I know what you're feeling, ninefinger, I've been in the same situation as you find yourself in now. My thoughts are with you and especially the young man.
   / generator to home panel connection #72
Then I suppose my plan to shinny up the pole and attach jumper cables is off the table? :D
Hey, while you're up there you may as well bootleg cable off of your neighbors line. Backup power ~and~ free cable.... Sweet!:D
   / generator to home panel connection #73
I think all of us have an idea what loss of life is like...I remember my best friend got killed when he was 16 yrs. old and an 8n tractor turned over on him...I drove an 8n at that time as well so it hit me especially hard...
   / generator to home panel connection #74
Thank you, Mr. Miller! :)
The subject of generators and backfeeding onto utility lines is definitely one that pushes ALL my buttons, as everyone has plainly seen! I'm quite passionate about it and I hope I don't come off looking like I am doing a personal attack on anyone. I have had a few friends and acquaintances injured (and one killed) from contact with high voltage lines. I once came this close(holding fingers a c-hair apart) to getting serious burned and possibly killed myself (through absolutely no fault of my own btw).
Pushes my buttons too. After Hurricane Andrew I spent 3 days out with DOT crews clearing downed lines and poles. I have a pair of 4' bolt cutters that will cut most any cable to get it out of the way. My worry was that someone had their generator wired to the house wrong. No wire cutting was done without the 20KV gloves on.
Our house has 2 manual transfer switches. A 50 A emergency panel inside for short term outages. And a 200 A outside for long term outages. As in 5 weeks without commercial power. Before the power company would power up the transformer, they inspected my installation. Took one look at the transfer switch and wanted to know where the 50 KW generator was.:D
Now as far as the circuit breaker lockout style, it is common on industrial panels. Don't like them but they are there. As are powered breakers that have motors to engage and disengage the breakers. But like all things man made, something can go wrong. Just ask the power company in GA that went to put a generator online and found it hitting the roof.
   / generator to home panel connection #75
I thought the original device described was clever (the mechanical interlock plate). It seems a bit disingenuous to to suggest someone might disable the interlock by removing it-- they can do that for any device installed including automatic transfer switches. If it doesn't seem to be working right, so just jump some wires from "A" to "B"...
What seems to be missing is that cheap and dirty solutions are far more common than the mechanical interlock plates. At least around here, it seems fairly common to use a simple suicide cord (male-male) to connect a genset through the dryer outlet, and to have to "remember" to cut off the main breaker:eek:.
For a while the local power company was offering something like the GenerLink. This seemed like a good idea, except that the monthly rental was 14.95 (plus taxes)!
I prefer automatic transfer with critical functions like computers running on UPSs. Being the NY Metro area with crumbling infrastructure, the power here isn't very good... short outages (less than 30S) about 6-12x/yr, longer outages (hours to a day) about 1-3x/yr and very long outages (1-18 days) every 2-4 years.
   / generator to home panel connection #76
image.jpg Don't see the issue if Eaton/Cutler Hammer sell them on their website saying they are UL listed and ROBUST
   / generator to home panel connection #78
Mace - thank you for a 10 minute chuckle. I will without any hesitation steal your "Stuck on Stupid" as a useful descriptor of those unable to change their brain gears.
As well, after reading through this thread, you've convinced me of one thing - I'm hiring an electrician to do a proper install of a proper switching system. Better safe then lawsuit.
hahahahahahah'stuckonstupid'hahahahhaahahahhh
   / generator to home panel connection #79
didn't realize this was such a polarizing item
There are those who will trade safety for the Almighty Dollar.
I haven't read the entire 8 page post yet but...........you are back feeding using a clothes dryer receptacle? Are you using a male plug with exposed live prongs on the generator side?
   / generator to home panel connection #80
i've worried about how much current is running thru the ground
I'm not an electrician but i don't think i've ever even seen a 30a dryer receptacle - every clothes dryer circuit i've seen was 60A, same as electric hot water heater
i am dying of curiosity - where did you see mention of a 30a receptacle? Running a 50a circuit thru a 60amp receptacle would seem to be on the safe side and having accumulated 577 hours on this generator, with no meltdowns, i feel kinda safe in assuming it is -
PS -
There is no current flowing through ground if wired correctly. Just what exactly are are you doing?
You are not an electrician, yup I could tell that a while back
Pure BS on the currents. An electric clothes dryer is a 120/240V 30 amp four wire plug. An electric stove is a 50 amp 120/240 four wire plug.
Just because it "works" doesn't make it right.
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2018 FREIGHTLINER...
2014 International Derrick Digger Truck (A55973)
2014 International...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
Pickup Truck (A59230)
