Generator switch broken. Now what?
/ Generator switch broken. Now what? #1
5030tinkerer
Iowa
Kubota GL3830/GL5030
I have a little Harbor Freight 11HP generator - the "US General Thunderbolt model 5708", made by McColloch (Harbor Freight Tools - Quality Tools at the Lowest Prices. My framer has been using it for power on the new home construction site and one of his guys evidently broke it - I found the on/off switch sheared from the base this evening. I am going to be calling McColloch tomorrow to see about getting a replacement, but does anyone know how these switches work? In other words, is there a way to bypass this switch for now to allow the continued use of the generator?
/ Generator switch broken. Now what? #2
Those on/off switches are usually a ground. When you turn it off, it CLOSES the switch to ground the stator? ie no spark.
but its one of 2 things. either it closes the ground circut, or it open's the spark circut. either way its easy to bypass and or wire in a simple toggle switch to do the same thing.
/ Generator switch broken. Now what? #3
Just take one of the wires off the switch and try to start it. It should run but you would have to touch the wire back on the switch or to a metal part of the generator (depending on which wire you removed) to stop it. Or if you have to, put the choke on to kill it.
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
HONDA Plate Compactor (A64553)
HONDA Plate...
1995 Skeeter 300ZX Bass Boat (A65579)
1995 Skeeter 300ZX...
Landhonor Quick Attach Screening Bucket (A66408)
Landhonor Quick...
2012 PROCO 130BBL (A65643)
2012 PROCO 130BBL...
Ford Truck Tire and Rim (A65640)
Ford Truck Tire...
