Generator repair
   / Generator repair #1
paulyny
Has anyone swapped out the generator assembly on a non working generator? I was given a 6000 watt generator with a honda 11hp engine that runs perfect except the windings on the electric motor went. Its a $2000 unit new so id like to give it a try. Any suggestions.
   / Generator repair #2
Could you use one of the HF generator heads? They are pretty inexpensive, but I have no idea if they make clean power.
Good luck, Dave
   / Generator repair #3
I've changed out engines and/or short blocks, but changing the generator end would probably not be worth the cost.
More info coming soon! (A53421)
More info coming...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
