Generator repair
   / Generator repair #1
paulyny
Has anyone swapped out the generator assembly on a non working generator? I was given a 6000 watt generator with a honda 11hp engine that runs perfect except the windings on the electric motor went. Its a $2000 unit new so id like to give it a try. Any suggestions.
   / Generator repair #2
Could you use one of the HF generator heads? They are pretty inexpensive, but I have no idea if they make clean power.
Good luck, Dave
   / Generator repair #3
I've changed out engines and/or short blocks, but changing the generator end would probably not be worth the cost.
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
1967 Ford F100 (A47477)
1967 Ford F100...
