Generator repair
   / Generator repair #1
paulyny
Bronze Member
Has anyone swapped out the generator assembly on a non working generator? I was given a 6000 watt generator with a honda 11hp engine that runs perfect except the windings on the electric motor went. Its a $2000 unit new so id like to give it a try. Any suggestions.
   / Generator repair #2
Could you use one of the HF generator heads? They are pretty inexpensive, but I have no idea if they make clean power.
Good luck, Dave
   / Generator repair #3
I've changed out engines and/or short blocks, but changing the generator end would probably not be worth the cost.
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
2019 CATERPILLAR 289D3 SKID STEER (A52705)
2019 CATERPILLAR...
Deer Gates (A53424)
Deer Gates (A53424)
