Generator Generator options
/ Generator options #1
Brian Miller
Acworth, NH
JD 2305
Hi,
Up where I live power outages are becoming more frequent so I'm looking to get a pto generator. To power up the house I doubt I would need more than 10Kw. However used 25Kw generators are readily available. I have a MF 1529 with about 26 pto hp. Is there any disadvantage to getting one of these generators? Will the generator still produce clean power. As I understand it I will get about 13Kw of power & no more. This would be more than enough for me.
Thanks
/ Generator options #2
Nothing wrong with a bigger PTO generator. You will have more inertia and will have less voltage loss with a surge load.
Do a search here - this has been discussed many times at length.
/ Generator options
Thanks.
I did do extensive searching but between that & talking with sales people, I was getting conflicting info.
I appreciate the response.
/ Generator options #4
what kind of price are you looking at for a pto generator???. I have a fixed , mounted 10k Onan propane generator that only cost me 1400 (used) about 14 years ago. Still works great after all these years. Its nice not to have to go and get the tractor out to run power to the house.
The 10K unit more than powers my house (4200 SF) incl lights, refer, freezer, gas furnace (fan) garage door openers, tv room. I DONT have a well or electric heat so 10K is plenty large.
Ive used PTO powered gen sets in the past, and they work fine. Have as clean of power as a motor operated unit. But i just prefer to have mine wired into a generator transfer panel that the wife can easily operate in a power outage. Im not sure how much tractor PTO is required per KW of generator power produced....there must be a chart somewheres out there.
/ Generator options #5
I think the biggest question you need to ask yourself is if you loose power can you split duties for the tractor between generator and storm clean-up. I know if it's a bad enough snow storm I'll need to keep my tractor free. Also you'll need a place to store the generator out of the way when not in use but close enough so you can get to it when needed. Of course a PTO gen doesn't have it's own motor or the servicing that goes with it.
I can make due with a 4.5K generator but I have to be careful and shut breakers off. I can run the well pump but if I buy something to replace my portable gas gen it would most likely be a 10k unit. If you can get a 25k cheap enough then I would but if you never think you'll use it I wouldn't pay any extra.
/ Generator options #6
How much propane will it use in a certain time frame??
/ Generator options #7
I have a 17kw propane generator wired into the main panel thru a tranfers switch. it came from northern 2 years ago for $3600 had everything but the battery for starting, sure is nice when the power goes out and the house comes back to life by itself. uses 1.3 lbs/ hr at full load.
/ Generator options #8
mines hooked up to a 500 gal propane tank, but im not sure exactly what it uses. i used to run it for about 6-8 hours on a 5 gal tank when i was framing my house, but it wasnt running at full load much. the fuel burn depends on the load. but im sure i can run mine for a heck of a long time on 500 gal of propane.....:licking:
now a 25k genset will EAT the fuel.
I install alot of generators and transfer switches (did one just this week), but i personally didn't want an automatic transfer switch on mine. If I'm not home, i don't want it running ....the freezer and frige will keep nicely for 24 hours without power.....why waste the fuel. Some people, especially those with elderly or infirmed in the house NEED the automatic transfer setup.....go for it. They are nice units out there. I also wire a majority of the new houses i do with a transfer capable panel (made by Siemens). the owner can add a generator with either a manual or an automatic option at a later time without replacing the panel. A regular 200 amp panel costs about $110 and the generator ready panel about $240.00. so its a low cost option for the future.
/ Generator options #9
Thanks for the info. I did not realize the price difference was that close. A worthy upgrade for sure.
/ Generator options
Thanks so much for all the info. Originally I was looking at a standalone diesel generator. My truck is a diesel, my tractor is a diesel, i've got diesel fuel around the house. But when I started doing some research I found a lot of 25Kw+ pto generators for sale in the area in the $1000-1500 range. For that price I figured a pto generator was the way to go, at least for now. We can live pretty comfortably without power for a little while- I heat with wood, & the well is gravity fed with the pump only for water pressure. There is still warm enough water 24 hours after the power goes out. And we cook with propane. But the last power outage was almost a week. I think I wouldn't worry about electricity during the day & just fire it up at night for a few hours. That way the tractor would be free for clean up work.
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
PT 1100 Gal Supply Tank (A64911)
PT 1100 Gal Supply...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2008 FORD F-150 PICK (A66091)
2008 FORD F-150...
2015 KENWORTH T880 (A67714)
2015 KENWORTH T880...
