generator ideas
/ generator ideas #1
glennd
Chipley, Fl
1954 WD45 eventually a compact diesel when I find 1 they're not so proud of.
I have aquired a 40hp diesel engine. Been trying to come up with a good practical use for it. We have several power outages per year and I'm currently wanting to make a standby generator and this engine would easily power the whole house. Found a 50kw generator head for $1,500 and was pretty impressed with the double throw 200amp cut out switches at $450. With switch, wire, enclosure, generator, etc... it's looking like it'll run a bit over 3k, that's a lot for me but a good deal for a 50kw set up. If anyone has a better suggestion for this engine or already assembled their own generator, I'd appreciate any tips. Thanks: Glenn
/ generator ideas #2
At 100% efficiency, you'd get just under 30KW with a 40HP engine. Reality would be less than 100%. One horsepower = 746 watts....................chim
/ generator ideas #3
In other words 30 KW would be a full load for that engine? I agree. 30 KW per hour is a lot of electricity. More than you would need to run most farms. /forums/images/graemlins/smile.gif
/ generator ideas
Need someone with a conversion chart to tell me what the HP is. It's a Deutz rated at 61KW. They didn't put a hp rating on it, just the KW. I was guessing, perhaps wrong. That said, 30 KW would be plenty and save me a bit of $$$. The lower kw generator is about $400 cheaper, but want to get it close to engines rated capacity in case it ends up somewhere else in the future. 20kw would run the house with the A/C. Yeehaw. Thanks and keep that info coming.
/ generator ideas #5
Horsepower X 0.7457 = Kilowatts
Kilowatts X 1.341 = Horsepower
And one I never ran into:
Horsepower (Metric) X 0.9863 = Horsepower
/ generator ideas
</font><font color="blue" class="small">( Horsepower X 0.7457 = Kilowatts
.................chim )</font> Many thanks for the information. That's incredible. Must stay focused on the gen. and put aside the homebuilt backhoe idea that just crept up. Did I mention it came with a hydraulic pump¿ Thanks again: Glenn /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
/ generator ideas #7
one things for sure...you're neighbors will love you because you'll have enough extra juice you'll be powering a couple, two, three of them as well /forums/images/graemlins/smile.gif.
/ generator ideas #8
I always heard it was 2 hp to generate one kw. Just checked hardydiesel.com and their 18kw unit has a 36hp motor. If this holds true, your 40 hp motor would match up with a 20kw genset. Still more than adequate for a home emergency generator.
/ generator ideas #9
Fractal, I didn't realize the efficiency was that low when I said it would be less than 100%. I have installed numerous generators, and never noted the engine HP on the shop drawings. Good info.
I have an old Onan LPG genset at my house, and at 5KW it provides enough 120V power to run the freezer, furnace, fridge, water heater and a "candle circuit" which gives a small amount of light and a receptacle in each room. Since the furnace and water heater are also LPG, they don't require much power. The only 240V loads are a range, clothes dryer and central air. I figured we'd just do without them. If worse came to worse, the microwave is 120V and there's always the BBQ grille.................chim
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
Buckhorn Poly Feed Box (A66408)
Buckhorn Poly Feed...
ASV Engine & Parts (A66285)
ASV Engine & Parts...
