Generator and propane tank sizing feedback needed
   / Generator and propane tank sizing feedback needed
Size the propane tank to the generator. My 22kw generac requires a MINIMUM of 500 gallon tank. The only things I have running off of propane is the generator and the furnace when it dips below 35 degrees outside. I have a 500, I wish I went with the 1000. Last year I think I used 200 but no generator runs in that.
I had an "evaluation" and was told for a whole house unit I would need 40kw. I told the guy i was not going to be roasting 2 turkeys and cooking the rest of thanksgiving dinner when the power is out while running the ac to cool the house to 59. He told me he would have to have me sign that the unit is undersized and warranty will be voided. I told him to get lost.
He must have added the max wattage of every motor, appliance, light and electric toothbrush in your house.
   / Generator and propane tank sizing feedback needed #42
He went to the breaker box and added all the amps up. I have 4-50amp breakers. Then 4-30 amp breakers. Then a whole bunch of 15s. 40 place box with only 2 remaining. New construction.
   / Generator and propane tank sizing feedback needed #43
Confused why folks need 24/7 gen running. Wood stove, lanterns, camp stove (or propane), rechargeable batteries etc can cut the run time to a few hours a day.
All the hot tub should need is one or two of those ag water trough heaters ranchers throw in the water to keep things from freezing.
Good topic- much good discussion and ideas
I think it's a matter of ability, attitude and outlook. My first instinct is inexpensive portable gen setup, circuit discipline, and making do with old fashioned solutions instead of all the modern stuff.
But other stuff quickly comes into play. Water storage solution if you are on a well. Pumping if you have a septic system with a pump. Can family members safely handle all the gear if the person who put together the subsistence solution isn't around?
Case in point: I love country living and DIY. My college-aged son has a city boy outlook. He can handle stuff if I am there coaching him about how and why to do things, but left to his own devices, he'd be in trouble, fast. Despite my best efforts. My wife loves country living and DIY, but has physical limitations. Chopping wood and moving a heavy generator are things she'll try hard to avoid (due to arthritis), even if it means paying a large propane bill.
   / Generator and propane tank sizing feedback needed #45
Rb - exactly. My parents are in their 70s and talking about a generator. They certainly won't be hauling out a portable and getting gas in cans.
   / Generator and propane tank sizing feedback needed #46
We have a Honeywell (~Generac) 22KW whole house unit here, installed last summer. There is a load management module on the 5 ton heat pump.
We already had a self owned 500 gallon above ground propane tank at the time of installation. Propane use, other than the generator, is as backup fuel for the HP system & supplying a set of seldom used gas logs (previous owners had a propane furnace & no heat pump). In the past we would generally refill the tank every other year or so, when the tank got to 50-60% full. I have just about talked myself into having a second 500 gallon tank installed parallel to the first.
My concern is that a full 500 gallon tank only has 400 gallons available & you can probably only use it down to about 100 gallons or so & still have adequate vaporization rates for generator under heavy load (or not so heavy & simultaneously running the backup propane furnace instead of the heat pump). If the tank is sitting at 1/2 full (~250 gallons), there is only about 150 gallons potentially usable generator + backup heat use, possibly representing < 5 days running full time, especially during a cold winter period.
A second tank would not only double the full tank total (800 vs 400), but would also allow a deeper draw while maintaining adequate vaporization rates (twice the surface area for a given level - so down to 100 gallons between two tanks?). In the 50% full scenario, with two tanks you have 400 gallons (500-100) of fuel potentially usable for generator + backup heat, easily well over a week even running full time.
Still thinking it over - Southern States will sell a new 500 gallon tank for about $1590 & do the delivery and installation w/plumbing for about $300. Looking at buying rather than leasing to avoid complications regarding who can fill what tank.
Nick
   / Generator and propane tank sizing feedback needed #47
In 1998 eastern Canada and the USA suffered from a major ice storm. My job required me to be out making certain schools used for shelters were up and running for citizens who had to leave their homes so I had to leave my wife and dog alone for about 16 hours a day for a few weeks.
At that time, I had a 3500 watt Honda portable and it would heat one room, run the well pump and the basics. My wife became skilled in load management for the generator shutting off some breakers while running others.
One night during this period, in the middle of a cold snap, my generator shut off. The crankcase vent line had frozen and all the oil in the crankcase was forced out. Thankfully the generator had a low oil shut down.
I started check the manuals of many different generators. Almost every brand said do not run below 5F.
What is one to do if it is -40F.
During this same ice storm period, a friend was running a portable generator which set his house on fire. The generator was running in the driveway which sloped towards the house.
The vibration of the generator caused it to slowly move down the slope until the exhaust was blowing against the garage wall which caught fire. No phones or cell service. The house was destroyed.
After that, I installed a 22 KW Generac which will run in the cold. I am now 71 and could not manhandle a portable generator. In 1998, I could lift my 3500 watt Honda into the back of a pickup by myself.
I tell people who ask me for advice, that their emergency plan should contemplate the strong, knowledgeable person in the family to be ill or away.
Dave M7040
   / Generator and propane tank sizing feedback needed #48
More initial cost, but diesel units are lowest cost to run. I have a 10KW Kubota driven genset which burns an average 1/3 gal/hr to run my house. Less than $20/day
paul
paul
That's a nice setup. How's the noise level?
   / Generator and propane tank sizing feedback needed #50
I converted a portable gas generator permenant. I have a 10kw from amazon that was $750. It'll run my whole house. When my power is out, it's typically winter, and fairly cold. My wood stove helps, but the way my house is laid out, I need my oil furnace and water pump to pump water through my house. My furnace is also my hot water, and i have a well pump, so when I run my generator I typically need to run it around the clock, especially at night when it gets cold. If the furnace goes out at night even with the fire going, it's not uncommon to wake up to a 50F house.
24in pin on tooth excavator bucket (A56435)
24in pin on tooth...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
NEW Fork Extensions (A59000)
NEW Fork...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
