General brand brushhog
   / General brand brushhog #1
RichOnLopezIsland
Lopez Island, WA
Shibaura SD-1840-FD and JD GT275
I recently purchase a grey market tractor with a brushhog. The brand appears to be "General". has onyone heard of this brand? I have no owner manual, how can I determine what it is rated for? Also, I'm having a hard time lining it up to hook up to my 3-point hitch. Seems like it should be way easier than it is. What are the secrets?:confused:
   / General brand brushhog #2
Bushogs are not hard. have you ever used a tractor before? Once you get used to it your faster everytime. Do you have the correct length toplink?
I don't know much about tractors. The bushog was attached when I got the tractor and I removed it. The trouble I am having is lining up the tractors two points with the bushog. It seems I can't slide the pin in if it is out of alignment by even a small amount. Should I attach the third point first or last?
   / General brand brushhog #4
Dont know anythig about the General brand bushhog,sorry cant help ya on that one. As far as the hook up issues I always unhook on level ground so when I go to hook back up I square up with my two points and able to get off the tractor with the loader off the ground and no brakes set. If the tractor needs to go forward or backwards a little i just grab a clete on the rear tire and push or pull while pushing the arm on the pin. The third is the last arm I hook up(after PTO shaft) then set it where I want it.
Thanks, that is helpful. I think I've figured out that the brushog is bent where the bolts go throug to hook it up. It'll just take some elbow grease to hook it up.
   / General brand brushhog #6
A good tool to have on hand is a heavy duty digging bar to use as a lever to wedge align the implement to the tractor's 3-PT hitch.
Set your 3-pt lower than the implement's pins and you should be able to then lift the arms in place and slide them on one at a time.
1997 John Deere 8100 MFWD Tractor (A53472)
1997 John Deere...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53472)
2-Row Peanut...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
