Generac or Koehler whole house generator?
   / Generac or Koehler whole house generator? #41
When i installed my unit, i fluctuated between the 22 kw air cooled and 22 kw liquid cooled unit. At the time the 1800 rpm liquid cooled unit was a real tempting draw.
But i realized our amount and lengths of outages didnt justify the additional $4,000 expense. Plus the unit was 2x as large. And alot more complicated to work on.
Its just plain frustrating to get a service call on a liquid cooled unit that shut down because a radiator sensor failed. There are so many sensors on these units, like a modern gas or diesel car. I like plain old air cooled units. Way, way less false alarms.
I used to maintain alot more large gas fueled liquid cooled units, but stopped doing them when maintaining inventory and training requirements got too expensive on the bottom line. The few i do now are for long time clients only.
I do suggest that anyone considerings a whole house unit do some real load calcs. I have seen too many people buy a , say 15 kw honeywell (generac) unit from costco and want me to install it on their 8,000 sq foot all electric house. Aint going to cut it.
The Smart Management Modules (SMM) that generac uses to shed loads work great, to a point. But its far better to size a unit for real load.
A 13 kw unit that has to run max output to power the house will eat more fuel than a 26 kw running at half load.
I also recommend a Soft Starter on large AC or Heat Pumps. They take out about 60% of the inrush start up load from the appliance. On my own 5 ton ac unit, all the lights in the house would momentarily dim when unit fired off. And really lug down the generator. After installing the soft starter, generator doesnt even hickup and no more lights dimming.
   / Generac or Koehler whole house generator? #42
For the cost of these larger units, I,,m surprised, and dis-appointed that these larger units do not have a transfer system that will power up the complete panel. I have a 11K unit that I manually switch into service, and it allows us to carry on our day completely normal. The only thing I would like to add is a light on the incoming side of the normal power feed so I know the utility power is back on, but it isn,t a big deal, cause one of our neighbours calls us when her back-up system shuts off and regular power is restored.
   / Generac or Koehler whole house generator? #43
I didn't read through all the replies since I read the thread yesterday so I apologize if this has been covered already. When I looked into the popular whole house generators I got disgusted. There are surprises, such as Kohler units have to have the oil checked every 8 hours or they can void your warranty! Generac says the following: "When your generator runs continuously for 24 hours, shutting it down for at least 30 minutes is essential. This downtime allows the unit to rest, oil levels to be checked, and a visual inspection to be conducted. Performing these steps proactively can help catch any potential issues early and maintain the longevity and reliability of your generator."
They can tell if the unit runs for more than the maximum continuous hours so it has to be shut down and restarted before the maximum time interval is reached. Generac's "free" extended warranty requires a "qualified" tech to service it regularly, which, of course, isn't free and increases the total cost of ownership vs doing your own maintenance.
Quality whole house generators that are rated to run continuously are big money, which is hard to justify for emergency power, so we recently bought another portable. As nice as it would be to have a whole house, fully automatic unit, I can't imaging powering everything down and then shutting down the genny to check the oil level every 8 hours for two weeks straight (the longest outage so far). Even having to do that once a day would be annoying. And if we were away from home when the power went out and the generator ran too long, the manufacturer just got an excuse to void the warranty. No thanks.
If you want a warranty, do not assume anything and read ALL the fine print before purchasing any whole house unit. Best to choose a brand that has a reputable company doing the service/warranty work in your area.
   / Generac or Koehler whole house generator? #44
Although I have a few generators, I MUCH prefer to power my whole house generator with my diesel tractor.
I always have it ready to go and if you want, you can park your pto generator near the house in a little house, just like you would have a stationary generator.
It's been working for me for many years now, so I have no plans to change.
SR
I do the same, but I can't dedicate a tractor just for generator duty. I have to remove the mower, spreader, etc and connect the genny to the PTO. I did mount it on a trailer, which I just roll up to the tractor instead of having to mount it on the 3pt. Even so, I'm not getting any younger and it gets to be a chore to hook up every time we have an outage.
As a result, I'm looking at a stand alone, electric start diesel model that I can just plug in when needed. An auto transfer switch is a possibility but not really necessary.
   / Generac or Koehler whole house generator? #45
It's $200 to have the annual service done on my Generac. To me that is worth the expense knowing it won't void the warranty
   / Generac or Koehler whole house generator? #46
Every generator I have ever seen, has a higher efficiency at 100% load, than at 50% load.
60-80% loading being the sweet spot for gasoline and propane maximum efficiency, and 70-100% for diesel generators.
So I’d have to disagree
   / Generac or Koehler whole house generator? #47
Im not sure about Kohler, bur where you read that a qualified generac tech has to do the service work. ANYONE can do service work on a generac and not void warranty. But you must keep all receipts for parts and keep records. If an engine fails during warranty, there going to want to see receipts and proof.
Its easier to have proof when its a certified tech receipt, but its not required.
Now, if it WARRANTY work, than yes, it can only be done thru a Generac certified tech.
Now as to checking oil, this is most important when unit is new. The engine valves and rings have not been fully seated and can lose oil. This thing (generac air cooled) only generally hold 1.7 quarts of oil.
If you truly dont want to check anything for extended time period, stick to liquid cooled. And only a liquid cooled that runs at 1,800 rpm.
   / Generac or Koehler whole house generator? #48
Again, im not sure what your talking about. I power smaller houses with gas appliances and heat on 11kw units with whole house switches. Its the large houses with all electric appliances that are the issue.
On some large homes with 2 electric panels (400 amp service split to 2 x 200 amp panels) i have even done installs where 1 panel is powered and one is not powered. This is when there all electric. I can place the large electric heat circuits in the non powered panel. This is done for clients that didnt want a 48kw generator.
   / Generac or Koehler whole house generator? #49
   / Generac or Koehler whole house generator? #50
Wow, Cub, I have not heard about that rule of checking the Kohler oil every 8 hours. I have a 2102 Kohler 17 kw air cooled propane generator, and it has been fine for these 12 years. And we do get a fair amount of outages up here, mostly when there’s a storm, and mostly due to trees falling on Hydro lines.
The one big advantage of the Kohler, is it is really quiet compared to all my neighbors’ Generators. Also, I have an automatic transfer switch, and it kicks in as soon as the power goes out. No big 10 second delay or anything like that.
Hot Pressure Washing Equipment Set (A56857)
Hot Pressure...
New/Unused 5ft Quick Attach Mixer (A57454)
New/Unused 5ft...
205196 (A52706)
205196 (A52706)
Caterpillar 725 Off-Road Dump Truck (A57453)
Caterpillar 725...
2016 KOMATSU D65PX-18 BULL DOZER (A58216)
2016 KOMATSU...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
