drizler
- Joined
- Jul 27, 2007
- Messages
- 733
Wow you guys sure do need the big stuff . I thought that emergency meant doing without or definitely less. I know you farmers need a large rig to run your needed operations .
Most folks up north here just keep a 5000 -7000 unit and do well with them. I had a 3200 GENERAC myself and still do though it’s a tad small. Recently I got a 17000 GENERAC from a guy who lives in the deep woods and wanted newer better. So I grabbed it for $100 with 200 hours on it. One thing I’ll say is wow it’s HEAVY and huge. It’s so big I can lay a piece of plywood on it and use it for a bench and weighs like a Harley. When we set it in the F 150 it actually dropped and could feel it back there driving home. As for being so called portable …..it ain’t really .
Mine range fine testing it and I know the guy so no concerned he’s ripping me off. I fire it up a couple weeks later ran it and shut it off. Now I always leave the carb dry if possible for well known reasons. Soooo me turns off the fuel and let it die which it did with a backfire. Yes it has the antibackfire solenoid on the Nikki carb same as on your Briggs mowers. Next month tried to start , nothin. Check around seems no spark , weak spark not sure really. As feared it must have sheared the flywheel key.
Now to get to the flywheel is a true adventure. Just taking the shroud off required everything off the front from the panel past the carb, intake. It sounds easy but it wasn’t. The panel really couldn’t be unhooked due to the way it was wired and and it stayed in the way most of the time. Finally I get to the flywheel and it looked fine but possibly had moved so I had to go bum a massive puller as mines smaller. It came off with the usual tapping and big bang . What do I see but the key is intact but seems a bit smeared. Put flyeel back onpart way and it’s obvious that it was a loose shallow fit and the kerf had just ridden over it. All that for a poorly fitted key. I took the next size up from hardware store and teased it down for a nice tight full fit. Together it goes , another battle with the shroud and panel cleaning out the carb along the way and it runs fine. I’m thinking the flywheel had already started moving which caused the violent backfire I’d seen.
Lesson learned, these things aren’t fun to work on at all. Everything is layered onto other things . If I was in a place where I needed one badly I’d want to stick a propane conversion on there and be safe from the dreaded Nikki carb hassles I know so well from my mower, same exact carb. The carb itself is easy but you have
unlike my mower ) to yank all that crap off to get to it. So do avoid if possible the Nikki nightmare with these especially if you are stuck with Booze-Gas . Store that carb dry or better use propane. One more think on Nikki. Those EBay rebuild kits and cheap toss on replacement carbs we all love ain’t so with Nikki. They either don’t have what you need or don’t exactly fit ( been there done that with mower ) . The toss ones you will notice aren’t well reviewed and look how few the selling company has sold, the bad comments ect. It took 3 orders to fix my mower becuse the tiny O rings are not in the kits and those are the usual culprit. Soooo if you do have to tear down ol Nikki do yourself a favor and spring for the OEM kit. It’s worth it in time and hassle.
