Generac GP5500 Compression
   / Generac GP5500 Compression #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Working on a 2011 GP5500 that is slow to start and in performing compression test I get 50 - 55 PSI max. Put a couple squirts of oil in cylinder and compression did not improve. Checked valve clearances and intake is .010 exhaust is .015 so I believe that should be adequate but don't know exactly what they should be. Now I am questioning if compression release is causing the low readings. Once it starts it seems to run fine.
Any other thoughts on what can check without dismantling the engine?
TIA
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
New/Unused SD Lanch SDLL50 Mini Skid Steer (A57453)
New/Unused SD...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A56860)
2025 Wolverine...
Mi-T-M Pressure Washer (A56860)
Mi-T-M Pressure...
New/Unused AGT Industrial LRT 23 Mini Stand on Track Loader (A57453)
New/Unused AGT...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
