Gelled fuel in 80 degree weather?
   / Gelled fuel in 80 degree weather? #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Yesterday my son filled my Yanmar YM2310 from the 5 gallon plastic fuel can. Today I removed the filler cap and looked into the fuel filler filter screen and noticed some sort of jell in the bottom of the screen. So I looked in the 5 gallon can and noticed a little water in the bottom. Maybe a teaspoon, certainly not any more. But I don't know if any water made it into the tractor tank. The fuel can seals tightly so I am mystified about the water. I buy my diesel from the pumps that folks fill their pickups from so that I think the fuel is pretty fresh. But the real mystery is the gelled stuff in the fuel filler filter screen. It can't be from cold weather. Could it be bacteria? Aside from buying bactericide to pour into the tractor tank and my 5 gallon can is there anything else I should do? I will be watching the fuel filter bowl to see in any water shows up.
Thanks,
Eric
   / Gelled fuel in 80 degree weather? #2
What kind of fuel do you run? Biodiesel?
   / Gelled fuel in 80 degree weather? #3
Biodiesel is something I will never purchase unless I had an
older model Mercedes diesel pre 1990's
willy
   / Gelled fuel in 80 degree weather? #4
Don’t wait for the sludge to run thru.!!
Your just waiting for a problem..
Drain the tank and flush it out..
   / Gelled fuel in 80 degree weather? #5
Don't eat the jelly! It's most likely bacteria. Makes me think of the movie "The Blob".
   / Gelled fuel in 80 degree weather? #7
Don't use it for jelly to spread on your bread:ROFLMAO:
willy
   / Gelled fuel in 80 degree weather? #8
Not sure about Washington State but in the Midwest from 4/15-10/15 on road pumps are mandated 10% or more Bio. Off road non taxed fuel is exempt from mandate. Bio can turn into peanut butter at colder temps so no on road for me during summer. Not usually clear jelly, more opaque.
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A51248)
UNUSED WOLVERINE...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
