Gears Grinding Badly
/ Gears Grinding Badly
Thanks for all the info, guys. I finally gave up and took it to a mechanic. There was oil leaking into the bell housing causing the clutch to stick. The mechanic opened it up and put new gaskets in and maybe a new clutch. He wasn't there when I went to the shop to pay. The receipt lists a clutch kit so I think he did something to the clutch as well.
This was a bigger job than I realized. The loader had to be removed and the tractor split in half. Not cheap either.
/ Gears Grinding Badly #22
yep.. that's what i suspected back in post 12.
many times the seal and gasket are under 10$ and the clutch.. at least for single stage small ones are under 400.. the rest is labor fo rthe split ( or more for a dual clutch.. etc.. )
soundguy
You were dead on. The clutch kit was just under $400. The bearings and gaskets were about $50. The labor was $1,100.00
/ Gears Grinding Badly #24
yep.. 'bout what i was suspecting..
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
