GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #1
JOE90
myhandra 4540 4 wd
Having a heck of time, every time I use the pto gears grinding. any help would be great
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #2
Are you engaging the PTO at idle speed?
My mower will grind a gear or two sometimes when it starts, but it's nothing major.
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #3
Likely 2 stage clutch. Make sure to fully depress the clutch, allow the PTO to stop turning, then engage, all at low engine RPM.
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #4
This. It's indeed a 2 stage clutch.
Essentially, the first half of the clutch pedal stroke is for the transmission gears, then the second half of the stroke is for the PTO.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
