GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #1
JOE90
myhandra 4540 4 wd
Having a heck of time, every time I use the pto gears grinding. any help would be great
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #2
Are you engaging the PTO at idle speed?
My mower will grind a gear or two sometimes when it starts, but it's nothing major.
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #3
Likely 2 stage clutch. Make sure to fully depress the clutch, allow the PTO to stop turning, then engage, all at low engine RPM.
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #4
This. It's indeed a 2 stage clutch.
Essentially, the first half of the clutch pedal stroke is for the transmission gears, then the second half of the stroke is for the PTO.
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
PALLET OF (2) THERMOKING TRI PAC UNITS (A50854)
PALLET OF (2)...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
