GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #1
JOE90
myhandra 4540 4 wd
Having a heck of time, every time I use the pto gears grinding. any help would be great
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #2
Are you engaging the PTO at idle speed?
My mower will grind a gear or two sometimes when it starts, but it's nothing major.
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #3
Likely 2 stage clutch. Make sure to fully depress the clutch, allow the PTO to stop turning, then engage, all at low engine RPM.
   / GEARS gRIND WHEN TRYING TO ENGAUGE PTO ON BUSH HOG #4
This. It's indeed a 2 stage clutch.
Essentially, the first half of the clutch pedal stroke is for the transmission gears, then the second half of the stroke is for the PTO.
1275 (A50490)
1275 (A50490)
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
2012 GENIE GTH1056 TELEHANDLER (A50854)
2012 GENIE GTH1056...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
