Gearbox 40hp vs 60hp
   / Gearbox 40hp vs 60hp #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I understand the power ratings and such but what are the physical differences in the boxes? Bolt patterns Im guessing and shaft sizes? I bought an OLDER brushhog unit cheap and am cleaning it all up (unknown make, model, etc) and the gearbox seems large (for a 5') so I was hoping to get an idea of the rating by the physical sizes if they do differ. I don't know if it is a light, medium or heavy duty but I would personally call it medium duty by the reinforcements on the deck and the thickness of the deck itself.
Thanks
   / Gearbox 40hp vs 60hp #2
since it's an older 5' machine.. i would treat it like light or medium duty anyway.. unless it looks built like a tank.. i wouldn't try to use it for a tank.
mosrt machines spinning a 5; hog are gonna be 20-30 hp..
soundguy
I am going to be running it on a 3700 Kubota so only about 30 PTO HP. so I figure I am safe either way. I am just trying to figure out the shaft sizes and box sizes between the two. I also find used gearboxes from time to time (used) and would like to understand the differences a bit more.
thanks!
   / Gearbox 40hp vs 60hp #4
good luck on the academic search.
soundguy
   / Gearbox 40hp vs 60hp #5
Thanks
The higher HP gearboxes have a "Diamond" mount 4 bolt pattern (That would have 1 hole directly under the input shaft). The smaller gearboxes have a "Square bolt mount pattern (4 bolts, 1 on each corner). Hope this helps. Ken Sweet
Thanks guys - the diamond shape makes it a lot easier to figure it out very quickly. I am really getting into buying and fixing implements up and also building new ones - sort of a new hobby for me and my 10 year old son (and sometime daughter if she feels what we are doing is somehow "crafty" - like painting.)
THANKS
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
Unused 2025 CFG MX15RX Mini Excavator (A49461)
Unused 2025 CFG...
2013 Cadillac ATS (A50324)
2013 Cadillac ATS...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
