Gear shifter spring
/ Gear shifter spring #1
Smoody
Platinum Member
South Carolina
YM226D
I have a YM2001 2WD, i was plowing a bit this evening and noticed the gear shifter was a bit hard to get in gear when trying to change gears on a slight incline. I almost had to force it into gear, seemed fine but about half hour later went to put in in reverse and teh shifter was loose, so i wiggle it a bit and sounded like it was broken, took the boot off and the shifter would lift out the tranmission, the spring on it is broken, please tell me this is a easy fix! thanks guys
/ Gear shifter spring #2
While I haven't done this . From your pictures , it looks east. Remove that C- clip & install new spring
ok, what is a c-clip, could you elaborate. I can work a wrench but this is only my second tractor.
/ Gear shifter spring #4
In picture # 3 (from left to rt. ) That little clip at the top of the spring. If that's the spring u are talking about
/ Gear shifter spring #5
For what it's worth; Put a rag over the shift hole before you try and snap off the clip. You know that clip will try and jump down into the gear box.
Dick
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2025 32in Tilt Bucket Mini Excavator Attachment (A66734)
2025 32in Tilt...
2019 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota...
2016 CATERPILLAR 304E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
2025 CATERPILLAR 265 SKID STEER (A65056)
2025 CATERPILLAR...
