Gear shifter spring
/ Gear shifter spring #1
Smoody
Platinum Member
South Carolina
YM226D
I have a YM2001 2WD, i was plowing a bit this evening and noticed the gear shifter was a bit hard to get in gear when trying to change gears on a slight incline. I almost had to force it into gear, seemed fine but about half hour later went to put in in reverse and teh shifter was loose, so i wiggle it a bit and sounded like it was broken, took the boot off and the shifter would lift out the tranmission, the spring on it is broken, please tell me this is a easy fix! thanks guys
/ Gear shifter spring #2
While I haven't done this . From your pictures , it looks east. Remove that C- clip & install new spring
ok, what is a c-clip, could you elaborate. I can work a wrench but this is only my second tractor.
/ Gear shifter spring #4
In picture # 3 (from left to rt. ) That little clip at the top of the spring. If that's the spring u are talking about
/ Gear shifter spring #5
For what it's worth; Put a rag over the shift hole before you try and snap off the clip. You know that clip will try and jump down into the gear box.
Dick
