Gear shift lock into gear
   / Gear shift lock into gear #11
"I took the next layer off and removed the "forks" and both of them slide independently. When one goes up or down the other is locked into position. The "balls" that they lock onto in the 2nd picture do not move freely. the bottom one jiggles for and aft but the front/top one does not"
This seems like a very unusual transmission! Usually the cluster gear is on bottom, and the sliding gears on top. I may not be looking at it correctly, but it seems like the forks go down into the trans oil, and the sliding gears are completely under the oil. I think the "balls" you mention are the upper most part of the forks (the rest of the forks are below the oil and are not visible)
It sounds like you are saying that in the "layer" you removed, the two shafts do go back and forth freely, and that the lock out function is working also.
The "balls" (forks) should slide freely on the shaft; and it sounds like you are saying that at least one of them (forks) is not. If it were me, I would begin by draining the oil so that I could see into the bottom of the transmission. It should be relatively easy to determine if the fork is 'bound' to the shaft, or if it is the sliding gear that is binding on the splines.
   / Gear shift lock into gear #12
It sounds like a mechanical issue with the gear selector on your Kioti LB 18914. If you're unable to shift out of 3rd gear, you may need to consult a certified mechanic or dealership to diagnose the problem and determine if disassembling the tractor is necessary to fix the issue. It's possible that there could be a problem with the shift mechanism or linkage, or an issue with the internal components of the transmission.
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 FORD F-550(INOPERABLE) (A55745)
2019 FORD...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
