gear reduction pressure?
/ gear reduction pressure? #11
Maybe if you park it with the front end downhill the air will go back out where it came in. /forums/images/graemlins/laugh.gif
/ gear reduction pressure? #12
/ gear reduction pressure? #13
</font><font color="blue" class="small">( Maybe if you park it with the front end downhill the air will go back out where it came in )</font>
Since we are talking about a sealed front axle/ final drive unit.. the air got in where the oil got in.. and as far as i know.. there is no vent... That was the point of the message.... no vent = pressure buildup due to air temp and atmospheric pressure changes..
Soundguy
/ gear reduction pressure? #14
Soundguy
/ gear reduction pressure? #15
It is my understanding that the front axles on these compact tractors are not supposed to be vented. The reason is because of the amount of water that they were originally designed for operation in. If the oil level is to high it will create too much pressure and cause leaks. This is one area that it would actually be better to be a very slight bit low on fluid than to have any amount of overfill.
/ gear reduction pressure? #16
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2011 ORTEQ TANK MANIFOLD (A60736)
2011 ORTEQ TANK...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
Rooster Weathervane (A55853)
Rooster...
