Loader GEAR PROBLEM
   / GEAR PROBLEM #1
ronnyarbiv
MCCORMICK MTX125 2004
HELLO,
I HAVE A MCCORMICK MTX125 WITH 5200 HOURS,
THE TRANSMISSION HAS 16 SPEEDS AND SHIFTED BY ELECTRIC BUTTON.
I HAVE A PROBLEM BETWEEN THE 8 GEAR AND THE 9 GEAR AND BETWEEN THE 12 AND THE 13 GEAR. SOMETIMES IT STACTS BETWEEN THE 9 TO THE 12 AND DOSN'T GO DOWN, OR STACTS IN THE 8 GEAR AND DOSN'T GO UP, IF SOMEONE HAS AN EXPERIANCE WITH A SAME PROBLUM, OR WAYS HOW TO SOLVE THE PROBLUM. THE OIL LEVEL TRANSMISSION IS O.K. AND THE BATTERY IS O.K. AND THE VOLLTAGE IS 14 WHEN THE ENGINE IS RUNNING.
THANK YOU!
   / GEAR PROBLEM #2
The changes you are having difficulty with are range changes where 2 gears have to shift!!
The system has error diagnostics built in what error codes are displayed??
Also on range changes a quick or time delayed change can be selected, which is yours configured to ???
What is the serial no of your machine????
   / GEAR PROBLEM #3
ronnyarbi
Awaiting your reply so i can help you fix this problem
I am the McCormick territory service manager who developed the field diagnostics on this gear change when it was first marketed by McCormick !!!
   / GEAR PROBLEM
Do you mean chassi number?
   / GEAR PROBLEM #6
The information i have is in a no of formats !!!
Are you operating a PC with windows or aMac with Mac OS ??
do you use Windows office "Word" & "Powerpoint" ???
Can u read "PDF" documents. ???
   / GEAR PROBLEM #8
Your tractor was built in early Nov 2003.
So i can get a feel for it some questions??
Are you the original owner ??
Do you know if it has had any suftware updates ??
Has the shuttle shift been modified by addition of an extra solenoid valve and anew controller ??
Some of the documents are too large to post on this forum, i meed your e mail address so i can send them to you, and i need answers re your PC and document reading capability ????
   / GEAR PROBLEM
I am not the original owner, but I have the tractor for 2.5 years.
I don't know if it has had any suftware updates
I don't think sow , how can I know, can you send me a picture so I can chek it?
my E-MAIL address -
arbiv.roni@gmail.com
thank you very much
   / GEAR PROBLEM #10
E mail sent with 10 documents for you to read through ????
The only person who can confirm which software is in the controller is your local McCormick dealer with his diagnostic laptop.??
See att Service Bulletin 6008 shows an extra valve fitted over shuttle block , located under rear of cab on top of transmission. Is this fitted ???.
  • D6008b.pdf
