Loader GEAR PROBLEM
/ GEAR PROBLEM #1
ronnyarbiv
MCCORMICK MTX125 2004
HELLO,
I HAVE A MCCORMICK MTX125 WITH 5200 HOURS,
THE TRANSMISSION HAS 16 SPEEDS AND SHIFTED BY ELECTRIC BUTTON.
I HAVE A PROBLEM BETWEEN THE 8 GEAR AND THE 9 GEAR AND BETWEEN THE 12 AND THE 13 GEAR. SOMETIMES IT STACTS BETWEEN THE 9 TO THE 12 AND DOSN'T GO DOWN, OR STACTS IN THE 8 GEAR AND DOSN'T GO UP, IF SOMEONE HAS AN EXPERIANCE WITH A SAME PROBLUM, OR WAYS HOW TO SOLVE THE PROBLUM. THE OIL LEVEL TRANSMISSION IS O.K. AND THE BATTERY IS O.K. AND THE VOLLTAGE IS 14 WHEN THE ENGINE IS RUNNING.
THANK YOU!
/ GEAR PROBLEM #2
The changes you are having difficulty with are range changes where 2 gears have to shift!!
The system has error diagnostics built in what error codes are displayed??
Also on range changes a quick or time delayed change can be selected, which is yours configured to ???
What is the serial no of your machine????
/ GEAR PROBLEM #3
ronnyarbi
Awaiting your reply so i can help you fix this problem
I am the McCormick territory service manager who developed the field diagnostics on this gear change when it was first marketed by McCormick !!!
/ GEAR PROBLEM
Do you mean chassi number?
/ GEAR PROBLEM #6
The information i have is in a no of formats !!!
Are you operating a PC with windows or aMac with Mac OS ??
do you use Windows office "Word" & "Powerpoint" ???
Can u read "PDF" documents. ???
/ GEAR PROBLEM #8
Your tractor was built in early Nov 2003.
So i can get a feel for it some questions??
Are you the original owner ??
Do you know if it has had any suftware updates ??
Has the shuttle shift been modified by addition of an extra solenoid valve and anew controller ??
Some of the documents are too large to post on this forum, i meed your e mail address so i can send them to you, and i need answers re your PC and document reading capability ????
/ GEAR PROBLEM
I am not the original owner, but I have the tractor for 2.5 years.
I don't know if it has had any suftware updates
I don't think sow , how can I know, can you send me a picture so I can chek it?
my E-MAIL address -
arbiv.roni@gmail.com
thank you very much
/ GEAR PROBLEM #10
E mail sent with 10 documents for you to read through ????
The only person who can confirm which software is in the controller is your local McCormick dealer with his diagnostic laptop.??
See att Service Bulletin 6008 shows an extra valve fitted over shuttle block , located under rear of cab on top of transmission. Is this fitted ???.
  • D6008b.pdf
/ GEAR PROBLEM
thank you for all the documents you sended.
I starded to set the range levers on the side of transmission case, then I did the calibration.
The result was C2 .
THE ERROR CODE WAS E9 & E7. I CLEARED THE ERROR CODE I DRIVED THE TRACTOR, I STILL HAVE THE PROBLEM WHIT THE SHIFTING, BUT KNOW THE ERROR CODE WAS E (NO ERROR).
MY FEELING THE PROBLEM IS ELECTIC.
1. DO YOU THINK THE PROBLEM CAN BE FROM THE UP & DOWN SHIFT BOTTONS?
2. I CHANGED THE ALTERNATOR 6 MOUNTS AGO, CAN THE PROBLEM BE FROM THE ALTERNATOR? (THE VOLL. ON THE BATTERY WAS 14V.)
I DIDN'T CHECK THE OIL PRESSURE, I DON'T HAVE THE KIT.
THANK YOU VERY MUCH!
/ GEAR PROBLEM #12
Good lots of good info here, and i now know you have error encoded software which helps the diagnostics.
Calibration error C2, Tight shifter rail or syncro in gearbox, or Loose lever on shaft which transfers shifter motion into box ( Did you do calibration with HANDBRAKE & FOOT BRAKES OFF ?????)
TEST , disconnect both levers from SSQ valve block and place gear levers on side of gearbox into mechanical neutral. CARRY OUT CALIBRATION CHECK WITHOUT RODS CONNECTED, DOES VALVE CALIBRATE WITHOUT ANY ERROR CODES ??? If o/k check tightness of levers on shafts, as servo valve rods will have set to neutral , adjust threaded rods to fit so pins slide home loosely.
Error codes E7 & E9 have they come back or are they still erased ???? (When these codes were present was it only once or multiple times ?? Error codes are stored in Controller and display shows the last 10 occurring codes
Your problem is most unlikely to be electrical !!!! and charging battery voltage of 14v is GOOD.
Problem IS NOT up / down change buttons
Next test you must do are the hydraulic cheks, this is where i beleive your problem lies ????
/ GEAR PROBLEM
hello,
I did calibration with handbrake & foot brake off.
I did calibration without rods connected, still the error code C2 appeared.
A fter we erased error codes E7 & E9 the error codes didn't appear any more.
We noticed that when we did calibration the arm that comes from the SSQ valve block wich is near to the gear box, didn't move at all.
Then we changed the electric wire, between the relay and the sensor, between the left side and the right side' and we started a new calibration, we noticed that the arm that comes from the SSQ valve block that is near the gear box moved but the other one didn't move.
Is there a test for the wires and the computer' for this problem?
I still didn't check the oil presure because I don't have the kit, is it neccasery, after this diagnose?
/ GEAR PROBLEM #14
O/K, good info.
As SSQ servo valve only moved on 1 side, then you changed connections and only other side moved, makes me think there is a connection problem in harness, or a fault with controller,
Re harness problem, you need to find controller, it is located under hydraulic console on right hand side of seat. you will need to loosen top cover , then remove side cover. you are looking for a silver box with a red and a black multipin connectors, (Both 36 pin) then checkout wires from these connectors to plugs on servo valve.
Sorry i hav no access at present to the wiring schematics ????.
/ GEAR PROBLEM
I am sorry I wasn't in the forom for a long time. I was out of the country. Folowing the tests you gave me to do. I checked all the wire between the SSQ servo valve to the controller (the silver box), it looked good.
I checked the wire from the button of the up/down change gir - it was O.K.
Do you have information to check the controller and the up/down button gir change?
I checked again the error code was E9 again, does it mean someting?
thank you.
/ GEAR PROBLEM #16
E9 means the 3rd/4th potentiometer inside the 3rd/4th gear piston in servo valve is shorted to high voltage (Damaged, Worn), sends bad signal to controller.
The potentiometer can be purchased as a separate part.
The controller can only be checked by aMcCormick dealer, using the ARGO (McCormick service tool (Laptop, software and comms protocol connection interface).
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
iDrive TDS-2010H...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
1143 (A63745)
1143 (A63745)
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
