Gear oil
/ Gear oil #1
bugwizard
Bolens G272
Just joined forum, looking forward to sage advise...I own a 1987 Bolens G272 diesel tractor. The manuals say to fill transmission with 36 quarts of SAE80 gear oil.
No where is it specified a GL-4 or GL-5. They are different, so I don't understand not stating which to use.
/ Gear oil #2
I wouldn't get hung up on the difference with a "seasoned" tractor of that vintage. Just putting new, correct weight oil in it is the important thing. 👍
/ Gear oil #3
Since you have the oil on the transmission drained, it's a good time to pull the screen out and give it a good cleaning, if it has one that is.
/ Gear oil
I'm changing the hydraulic oil filter once I establish the correct gear oil designation.
Thanks for your reply.
/ Gear oil #10
Bugwizard, you say you’re changing the hydraulic oil filter. Do you mean you’re putting in a new strainer element or are you changing it out for another filter altogether? I ask because I’m having issues with my g274 strainer. The mechanic tore the old one up (I have no idea how) and put the housing back on and didn’t say anything. I Found the strainer tossed in the yard and had a look inside and sure enough it was empty. He’s since been given the boot and I’ve been looking for a solution that doesn’t require me to buy a new one from overseas. Also, what filter do you have fore the engine oil? He also threw on a spin on hydraulic filter for the engine oil. I can’t seem to find specs for filters anywhere so whatever you have on yours must be better than mine.
2015 John Deere 3046R Compact Utility Tractor (A63116)
2015 John Deere...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
Domar Land Plane CA120 (A64047)
Domar Land Plane...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2014 BIG TEX 35 T/A GOOSENECK TRAILER (A63569)
2014 BIG TEX 35...
2021 John Deere Z930M Zero Turn (A63116)
2021 John Deere...
