GEAR OIL?
/ GEAR OIL? #1
bubblesbacon
eagle river, wisconsin
1955 case vai
I need to change/fill the rear end of the drive train on my 55 Case VAI, it states to use no. 90w oil? a straight 90wt that I am having trouble finding, also in researching this I came across some stuff on GL-1 good and GL-2 thru 5 possibly bad for old tractors because of yellow metals used internally? rather confusing, I just want to yuse the right product and where to find it at a reasonable price... this is not the torque tube / hydraulic pump oil, just the trans/rear end oil/lubricant I am finding trouble understanding whats out there... not a fan of synthetics either...
Any one with some words of wisdom?
/ GEAR OIL? #2
napa sells a gl1 90w geatr oil.. 65-205 i believe is the part number for a 5g pail. 65-201 might be 1g jugs. verify that.
many TSC sell a 90wt gl1-3 oil branded for ford trannies from 39-52
lastly.. you can find 80w90 gl4/5 oil that carries a MT1 rating and / or states yellow metal safe.
SOMETIMES walmart has that.
/ GEAR OIL? #4
gl 1-3 are completely sae for ym. when you hit gl4 and 5 some oils will have addatives that can contribute to attacking yellow metals.. especially in the presence of moisture.
many oils are now formulated to not use those ep addatives that attack the yellow metal. many times they will carry a MT1 rating and or simply say yellow metal safe.
Ford N and old fergy need this type of oil due to having a belly hyd pump that is very spendy, and is just loaded with yellow metal.
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
BRADLEY MACHINE  MINI VAC TRAILER (A67714)
BRADLEY MACHINE...
PORTA POTTY (A68842)
2013 HAULMARK ENCLOSED UTILITY TRAILER (A67714)
2013 HAULMARK...
2007 BIG TEX 20 T/A UTILITY TRAILER (A67714)
2007 BIG TEX 20...
2018 Komatsu D51PXi-24 Crawler Tractor Dozer (A66734)
2018 Komatsu...
