gear oil mix
   / gear oil mix #1
bcarmalt
kubota L4500
Greetings all
I have a JD Rotary Mower which had not been used for a couple of years. Opened the gear box and the level of gear oil looked a little low. So, in our shed we had some Universal Tractor Fluid which I added (about 1 cup). Then I checked the JD manual and it calls for API-5 gear oil. Looking at the container, I could not find an API rating, but at Tractor Supply I read another UTF that had an API-4 rating.
Will I be doing serious damage to the mower?
Thanks
   / gear oil mix #2
1 cup isn't likely to hurt, but a couple of years of sitting should warrant a oil change anyways. My JD mower lists several acceptable gear oils, 80W90 the most common.
   / gear oil mix
Thanks Wolfy, I did not think a cup would hurt, but its nice to get a second opinion. Also, I would not have thought about the oil change, but that is a good idea. Another task for the to do list.
   / gear oil mix #5
I agree 1 cup not going to do any harm. When you change the fluid, damage will occur if you use an "API-4" lubricant. The API GL 4 rating has insuffcient EP additives to properly protect the system from spalling. If your manual calls for a GL-5 rating, be sure to use that.
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
