gear oil mix
   / gear oil mix #1
bcarmalt
kubota L4500
Greetings all
I have a JD Rotary Mower which had not been used for a couple of years. Opened the gear box and the level of gear oil looked a little low. So, in our shed we had some Universal Tractor Fluid which I added (about 1 cup). Then I checked the JD manual and it calls for API-5 gear oil. Looking at the container, I could not find an API rating, but at Tractor Supply I read another UTF that had an API-4 rating.
Will I be doing serious damage to the mower?
Thanks
   / gear oil mix #2
1 cup isn't likely to hurt, but a couple of years of sitting should warrant a oil change anyways. My JD mower lists several acceptable gear oils, 80W90 the most common.
   / gear oil mix
Thanks Wolfy, I did not think a cup would hurt, but its nice to get a second opinion. Also, I would not have thought about the oil change, but that is a good idea. Another task for the to do list.
   / gear oil mix #5
I agree 1 cup not going to do any harm. When you change the fluid, damage will occur if you use an "API-4" lubricant. The API GL 4 rating has insuffcient EP additives to properly protect the system from spalling. If your manual calls for a GL-5 rating, be sure to use that.
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55301)
Adams Load Out...
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
