Gear lube for brush hog
   / Gear lube for brush hog #1
momark
What is the best viscosity gear lube to use for a brush hog gearbox? It is an older 5' model. Not sure of the manufacturer. Thanks for any help.
mark
   / Gear lube for brush hog #2
mark
Some manuals call for 90WT gear oil. Some say 120WT. I've seen several old mowers with leaky gear box seals using pourable grease or even regular "axle grease".
   / Gear lube for brush hog #3
momark:
Welcome to TBN :)! I have had 3 rotary cutters: Woods M-40 (40"), Tebben TC96-40 (40"), and a Tebben TC94-500 (60"). Recommendations for gearbox lube were always 80W-90 gear lube. Jay
   / Gear lube for brush hog #4
On an older unit.. I'd use 85-140, unless i knew the specs called for 80w90.
If it leaks a little, use JD cornhead (pourable) grease.
If ya can't get it, any 0# grease will work... or just get most of the gear oil out and pump in regular tube grease, and let it mix with the remaining gear oil to make a sticky flowable mess..
Soundguy
   / Gear lube for brush hog #5
I'd use 85-140. It'll be less viscous at startup than 80-90w that most specify and be more effective in getting lube swirled around quicker.
Ralph
   / Gear lube for brush hog #6
why are there so mach variation on price on brush cutters...i see on ebay some are buy now for $750 and some are much cheaper....i have a 4 ft and a 5 ft and don't know the name on either...i don't see a brand name anywhere on them...both work properly and i was thinking of selling one of them? any thoughts?
   / Gear lube for brush hog #7
some light duty, some medium duty, some heavy duty, Heavy duty being priced higher. Some will have higher rated gear boxes.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
FAKE (A52472)
FAKE (A52472)
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
