Gear box oil
/ Gear box oil #1
lil_country
Bronze Member
Central Oklahoma
2006 B3030 & 2006 Cub Cadet LT1045
I have an old brush hog that is still giving good service. I want to change out the gear oil. What is best to use in the gear box?
/ Gear box oil #2
80W90 is quite widely used, but I've noticed that it gets pretty thin here in July/August. Especially when the mower is parked and the tranny cooks in the brutal sunshine. If your part of OK is hotter than my part of KY, you might want to consider 85W140. I'm going to top mine up with 140W in the spring.
//greg//
/ Gear box oil #3
Unless you own a old worn out one like mine that likes to leak everywhere. I filled mine a couple of years ago with a NGLI# 00 rotary mower grease, same stuff I use in the old snow blower gear box. Not a leak since. :)
If yours isn't a old antique rattle trap like mine a 80 to 140 weight gear oil (depending on operating temps) should be fine. Personally I would probably go with a multiviscosity 85W/140 like Greg suggested.
/ Gear box oil
Thanks for the responses. It is very old, but doesn't seem to be leaking at all. I have read some discussion of using grease, but I didn't know if it was good for general practice or just for old mowers with leaks. And I didn't know if there might be some brand new whiz bang high tech lube that I had missed out on.
/ Gear box oil #5
I use NGLI# 00 grease in alot of equipment I have that has old gear box's. It's not like the grease in your grease gun. 00 grease is a semi-fluid and is not solid like you would think of with a NGLI# 2 grease. It's almost more like a heavy/thick gear oil, one reason it's great at stopping leaks. :)
/ Gear box oil #6
If you want that brand new whiz bang high tech lube kinda feeling you can get a tube of STP gear lube additve which is very high in ZDP content. Has lots of EP (Extreme Pressure) and AW (anti Wear) properties. $3 a tube at auto parts stores.
New/Unused Electric Winch (A65583)
New/Unused...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2016 GMC Sierra...
2010 ALTEC DIGGER DERRICK (A59914)
2010 ALTEC DIGGER...
Spartan SRT-XD Zero Turn Mower (A66285)
Spartan SRT-XD...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
