Buying Advice Gc2600
   / Gc2600 #11
I bought a 2610 before I discovered that it is the same as a 2410, and that the same motor is simply run a little faster to get more power. I have a 2010 model with 75 hours on it that is usually run slower than the rated speeds.:confused:
   / Gc2600
May sound dumb but what do you mean it usually runs slower than rated speeds? Why?
   / Gc2600 #13
Apparently, they both use the same engine; the 2610 may or may not have other tweaks, but the it's "set" to be able to run at a slightly higher RPM to gain that extra hp. Rated PTO speeds (540/2000) are set at the higher RPM level.
Thing is, many of us who have GCs find that they'll do a more than adequate job at less than "full, rated hp/RPM." And use less fuel as a result. That's one of the biggest reasons I got the GC over the Kubota- they generally have to run at a higher RPM, as I understand it.
I'll sometimes run the MMM at 2000 RPM, but usually lower; only use 2000 with the snowblower if the snow's wet & deep; otherwise 1500-1800 is plenty. Backhoe/FEL work rarely takes more than a fast idle, unless I'm trying to pull a stump or lift something that's quite heavy.
You'll see when you visit my pal in Leeds--see PM.
   / Gc2600 #14
The Massey Ferguson 2410 or 2610 can lift all four wheels off the ground with the tractor at an idle. We have a lot of customers with the GC models and very few are unhappy. The difference between the 2600 and the 2400 series is about $500.00. In operation there would be a noticeable difference in implements like a brush hog.
   / Gc2600 #15
Hi, I had a 2006 with mmm and no fel
I just traded it against a tlb,kept my mmm
Very satisfied, excellent machine, nothing to say,very dependable and easy to service
   / Gc2600 #16
Pictures pictures and what did you buy?
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
40' CONTAINER (A52706)
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
