3-Point Hitch GC2410TLB 3 Pt hitch goes up, stays up, and blows seals
   / GC2410TLB 3 Pt hitch goes up, stays up, and blows seals #1
thecnwcaboose
Sheboygan, WI USA
2012 MF GC 2410 TLB, 1951 Ford 8N, 1958 Ford 861
My MF GC2410 3 point arms go up, stay up, and I cannot get them to go down. They over pressure the system, and hydro oil blows out the seal for the 3pt actuator valve under the rear fender cowling ALL OVER.
I replaced the pin which actuates the spool inside the cover where the handle links to and the gasket for the cover. The system still over pressures, even with my pushing the handle down.
I am very sad. :(
   / GC2410TLB 3 Pt hitch goes up, stays up, and blows seals #2
Sorry to hear that!
Any possibility of a mechanical issue with the raise/lower control arm(s) & linkages? Perhaps a stick jammed up there holding control in RAISE position?
Linkage is all free. I have the rear fender and seat tore off and am able to see the entire linkage chain.
I am guessing this is more internal... sadly
   / GC2410TLB 3 Pt hitch goes up, stays up, and blows seals #4
I am very sad. :(
Do you hear your relieve valve? Check all the linkages make sure they are adjusted properly. Also check for leaking hoses and connectors. Sometimes these leaks happen when there is air in the system. Make sure your hoses are connected correctly.
Relief valve is actuated and system is "stuck" wanting to go up even though I physically push the 3 point gray handle down. The system over pressures and blows out the cover seal where the linkage goes into the TX housing casting.
   / GC2410TLB 3 Pt hitch goes up, stays up, and blows seals #6
Is hydraulic line coupler in the rear completely seated?
   / GC2410TLB 3 Pt hitch goes up, stays up, and blows seals #7
Is it position control? Sounds like the feedback mechanism is out of whack. That is what would tell the hydraulics to stop raising.
   / GC2410TLB 3 Pt hitch goes up, stays up, and blows seals #8
Agree. Someone adjusted the feed back to get the three point to raise higher, or the feedback rod is either, bent, broken or missing.
   / GC2410TLB 3 Pt hitch goes up, stays up, and blows seals #9
Yeah a malfunctioning 3pt can be dangerous so have a professional look at it.
   / GC2410TLB 3 Pt hitch goes up, stays up, and blows seals #10
sounds to me like you have the rear hoses looped improperly, swap to the other one and see if that works.
Kubota KX033-4 Midi Excavator (RIDE AND DRIVE) (A50774)
Kubota KX033-4...
Landoll Hauloll (A52748)
Landoll Hauloll...
2015 Chevrolet Express Shuttle Bus (A50323)
2015 Chevrolet...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
