GC2410 Replacement Oil Filter Part Number
/ GC2410 Replacement Oil Filter Part Number #1
Cutlass65
Lakefield ON
Massey Ferguson GC2410TLB
Getting ready to do my spring oil change and I have decided to go aftermarket for the oil filter. When I researched the part number on this site I came up with two different Fram part numbers. I found PH4386 and PH4746. Which one is the correct one? Can someone advise which to use or does it matter?
/ GC2410 Replacement Oil Filter Part Number #2
Should be a NAPA 1360. Which neither of those numbers cross to. ( Iseki 3 cyl ??)
/ GC2410 Replacement Oil Filter Part Number #4
When I interchange the OEM filter into my NAPA system, or look it up by direct application, it comes up 1360
Filter O.D. (Inches) : 2.685"
Flow Rate : 7 To 9 gpm
Gasket I.D. (Inches) : 2.2"
Gasket O.D. (Inches) : 2.46"
Gasket Thickness (Inches) : .23"
Height (Inches) : 2.577"
Media Type : Cellulose/Poly Blend
Style : Spin-On Oil Filter
Thread Size (Inches) : 3/4-16
Filter O.D. (mm) : 68 mm
Gasket I.D. (mm) : 56 mm
Gasket O.D. (mm) : 62 mm
Gasket Thickness (mm) : 6 mm
Height (mm) : 65 mm
The PH4746 crosses to a NAPA 1394
Flow Rate : 7 - 9 gpm
Gasket I.D. (Inches) : 2.173"
Gasket O.D. (Inches) : 2.475"
Height (Inches) : 2.977"
Media Type : Glass Enhanced Cellulose
Style : Spin-On Lube Filter
Thread Size (Inches) : 3/4 - 16
Burst Pressure : 400 psi
Gasket I.D. (mm) : 55 mm
Gasket O.D. (mm) : 63 mm
Height (mm) : 76 mm
Either filter will "fit" but the 1360 is the one we would use in our shop.
We are a NAPA store also. Just for heads up. ANY Napa store should be able to cross your OEM filter number. It's one of the best features they have, great interchange info.
/ GC2410 Replacement Oil Filter Part Number #5
If you compared the OEM filter, to the 1360, you would also find insignificant differences.
The problem with the NAPA, or the (Wix filter, made by the same machine), is, the OEM filter retails for the same price.
People are often looking to pay a more reasonable price, than roughly twice what it should be.
