GC2410 mid PTO cover
   / GC2410 mid PTO cover
I can't understand why Massey doesn't include a cover for the mid PTO. I would think that all sorts of dirt and debris might get in there and damage the internal splines.
Also, what are you suppose to do with the mid PTO when not in use? It looks like it could get damaged just hanging there. Is it supposed to attach up to a bracket or something when not in use?
Sorry for all these questions, but I didn't get a manual for my MMM. The dealer is sending it to me though.
   / GC2410 mid PTO cover #12
Take that end of the shaft off! There should be just a small shaft that comes out from the transmission. Nothing should be hanging.
   / GC2410 mid PTO cover #13
^^^Don't leave ANYTHING attached to the male end sticking out of the tranny, if you don't have an attachment on using it!! You could do some expensive damage! Not yelling at you, just want to make it clear that you don't do that.;)
So do I have take the universal apart to remove the yoke, or does the yoke and universal just pull out together?
   / GC2410 mid PTO cover #15
Up at the rear of the shaft, towards the tractor, there is a ring at the end of the pto shaft. Pull the ring towards the front of the tractor and then pull and slide the shaft off the tractor.
   / GC2410 mid PTO cover #16
DC3- here's a pic of the MMM removed, with its driveshaft still attached. That's the way I keep it during the summer, but for winter storage (on edge, with some wheels), I remove the driveshaft/U-joint and store it elsewhere. (That's where the "Mower Deck" comes in....)
Oh, yeah-- you can see the quick-release ring at the end of the driveshaft on the right; that's what Wacky was talking about.
   / GC2410 mid PTO cover #17
Where did you get the wheels to store it on edge? Are they the ones that attach to the deck?
   / GC2410 mid PTO cover #19
Instead of removing the end of the shaft to store over the winter. Remove the left belt guard and rotate the shaft and put the universal joint under the guard. It makes a great place to keep it from falling off or getting in the way when moving it. I have also removed the nuts that hold the belt guards on and put a little bend in the guard and the front clip holds the guard on nicely with out them. It make greasing the deck easier.
Doug
MMM nut less belt guard.
   / GC2410 mid PTO cover #20
Hmmmm... "nutless belt guard".... OK, I won't go there!:laughing::laughing:
Seems this thread is generating some rather interesting thoughts!
But that does sound like a great idea, tx2310! I've always hated having to remove those nuts to lube the thing! (Got any pics of that "little bend"?)
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
Scag 36 Advantage Push Mower (A50121)
Scag 36 Advantage...
2013 Ford F-550 Altec AT40G 40FT Bucket Truck (A50323)
2013 Ford F-550...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
