Oil & Fuel GC2400 - Water in front axle
   / GC2400 - Water in front axle #11
One member years ago, had a failure of the front gears on a GC2300. MF replaced the gears. They must have known there were defective ones out here, because they didn't argue.
Use the 4WD if you find you need it. But, don't use it, if you don't have to.
Some people just leave it in 4WD all the time. I wouldn't recommend that, especially with a lot of weight in the front bucket. Or, on paved roads. The front tires need to be able to slip, If they can't, damage can occur.
Leaving it in 4Wd all the time, also wears the front tires out faster.
   / GC2400 - Water in front axle #12
I find that I need 4wd almost all the time on my 2022 GC 1723EB. It's not like these small machines have a lot of traction ...
   / GC2400 - Water in front axle #13
Depends on what you are doing with it, and how you use it.
I find that I almost never need my 4WD. And, I plow snow on gravel, with turf tires.
Sometimes, I went half the winter, before I realized I hadn't engaged the 4WD.
Yeah, if you like to play in the mud, or go running around the woods, that's what 4WD is for. I don't do that.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
2021 GMC Sierra Pickup Truck, VIN # 1GTP9EEL4MZ178676 (A57453)
2021 GMC Sierra...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
546 (A52708)
546 (A52708)
