GC2310 steering wheel loose - rubber bushing replacement
   / GC2310 steering wheel loose - rubber bushing replacement #21
According to the parts books it's the same unit for all the GCs. The only difference I can see for parts is that the new models don't have the rubber bushings, at least according to the parts book (but I could be missing it). The unit in the new models is also mounted lower on the column with a longer shaft and u-joint for the tilt steering instead of being connected directly to the steering wheel with a short shaft.
This was one of the reasons that I chose the GC in the first place, because, for the most part, all the parts or at least 90% of them are all the same. Massey might not sell a lot of them but with so many models all using the same parts the likelihood of becoming obsolete or unavailable is smaller.
   / GC2310 steering wheel loose - rubber bushing replacement #22
If the "unit' in the new models has a longer, and different type of shaft, mounts in a different place, and in a different fashion, that seems to strongly suggest the "new unit" is not a compatabile replacement part?
   / GC2310 steering wheel loose - rubber bushing replacement #23
Sorry, you are right, I must have looked at wrong book for the new model, is does use a different controller.
   / GC2310 steering wheel loose - rubber bushing replacement #24
still. most people w/o power. I got power but....****...been a long 4 days.
   / GC2310 steering wheel loose - rubber bushing replacement #26
yeah thankfully I got generator. posted that by accident, was typing message to friend and got distracted and typed it here LOL
2004 Fleetwood Wilderness Travel Trailer (A50324)
2004 Fleetwood...
Case-IH 160 Puma (A50120)
Case-IH 160 Puma...
Gleaner R50 Combine (A50514)
Gleaner R50...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
Livestock Oiler (A50515)
Livestock Oiler...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
