GC2310 steering wheel loose - rubber bushing replacement
   / GC2310 steering wheel loose - rubber bushing replacement #21
According to the parts books it's the same unit for all the GCs. The only difference I can see for parts is that the new models don't have the rubber bushings, at least according to the parts book (but I could be missing it). The unit in the new models is also mounted lower on the column with a longer shaft and u-joint for the tilt steering instead of being connected directly to the steering wheel with a short shaft.
This was one of the reasons that I chose the GC in the first place, because, for the most part, all the parts or at least 90% of them are all the same. Massey might not sell a lot of them but with so many models all using the same parts the likelihood of becoming obsolete or unavailable is smaller.
   / GC2310 steering wheel loose - rubber bushing replacement #22
If the "unit' in the new models has a longer, and different type of shaft, mounts in a different place, and in a different fashion, that seems to strongly suggest the "new unit" is not a compatabile replacement part?
   / GC2310 steering wheel loose - rubber bushing replacement #23
Sorry, you are right, I must have looked at wrong book for the new model, is does use a different controller.
   / GC2310 steering wheel loose - rubber bushing replacement #24
still. most people w/o power. I got power but....****...been a long 4 days.
   / GC2310 steering wheel loose - rubber bushing replacement #26
yeah thankfully I got generator. posted that by accident, was typing message to friend and got distracted and typed it here LOL
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52128)
2014 Yale 3 stage...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
