gc2310 dash lights & glow plugs
   / gc2310 dash lights & glow plugs #1
johnybztr
Fall RIver, MA
husqvarna, z5424 , 24hp Kawasaki ZTR
What's up all, I got a used 2006 gc2310 about a year ago and it always started fine but we had a few cold mornings and I think my glow plugs are not working . Should I be turning the key to the left? When I do there is no noice or lights, I am thinking a light should light up and go out when it is ready to start? Thx
   / gc2310 dash lights & glow plugs #2
   / gc2310 dash lights & glow plugs #3
?? Mine's a 2007, the key is turned to the left (and held for the desired time) for glow plugs, then to the right to start.... but I also have no glow plug indicator light.
   / gc2310 dash lights & glow plugs #4
I have a 2004 GC2310, my key turns to the left (counter clockwise) for the glow plug position, and I am told the glow plugs stay on as long as the key is held in this position. I had to go 40 sec. to start the tractor.
This season I had a problem where it wouldn't start in the cold temperatures so I had a professional come to diagnose the problem. He told me the problem was the glow plugs, so he replaced them and said it needed a new relay since the new glow plugs were higher amperage. I had sticker shock with the price of parts-3 glow plugs for $210 and the relay was $180, do these part prices sound correct?
   / gc2310 dash lights & glow plugs #5
How many hours on the machine?
I can tell you, no one I know of on TBN, has ever experienced a single glow plug failure on a GC, let alone all of them.
Not saying it isn't possible. But, you would be the first one. So, I am not too sure.
40 seconds would not be unusual if it is very cold.
   / gc2310 dash lights & glow plugs #6
The machine only has about 650 hrs on it.
   / gc2310 dash lights & glow plugs #7
Any idea where the relay would be located? I was looking around the machine for new parts but didn't see any new electrical components.
   / gc2310 dash lights & glow plugs #8
My guess is under the dash.
You should be able to listen for it, when you turn on the glow plugs.
   / gc2310 dash lights & glow plugs #9
Thanks Ray! I will take a look there.
   / gc2310 dash lights & glow plugs #10
I have seen glow plug failures, only twice, but it does happen. However, I'm pretty sure that glow plug relay is no where near $180. 3 glow plugs would be expensive, probably not $210 either though. Did he charge dealer pricing? sounds like he marked them up too? Have you changed your battery ever?
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
6" & 8" I BEAMS UP TO 16' LONG (A51247)
6" & 8" I BEAMS UP...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
