GC2310 Bachoe removal.
   / GC2310 Bachoe removal. #1
aesanders
Platinum Member
Alachua County, Florida
LS MT3 42 S HST cab, BCS 830 2 wheel tractor, Gravely Pro-Turn 160 XDZ, John Deere Gator HPX 615e
For those that have this machine, how easy is removing the backhoe?
Does the 3 point hitch stay on all the time unlike the BX machines that require you to remove the 3 point hitch?
   / GC2310 Bachoe removal. #2
Easy, just use the hydraulics to lift it off ( after you remove the pins ) just be sure to connect the two hydraulic hoses after. I did not do this to start with and I had no 3 point action. After reading the manual and hooking up the hoses all was good. Should have read the manual! I only ran the tractor for a couple of minutes so I don't think any damage was done, as I think the hydraulic system would have a relief valve....
Thanks for the respone.
The 3 point hitch stays on the tractor from what I understand. This seems like a better system than the Kubota uses in which you have to remove the 3 point arms when mounting the backhoe.
This is an important feature for me as I will be using a small rotary cutter farly often and will need to pull the hoe off the machine regularly.
About how long does it take to remove the backhoe?
   / GC2310 Bachoe removal. #4
I am using a brush mower as well, actually have not got it yet but it should be in this week, a Massey 1004. Haven't seen to much on it, so i hope it works well.... as far as the time.... around 2-3minutes to take it off, then unfold the 3-pt hitch arms, hook up your implement and give er.....
2011 Chevy Avalanche (A50324)
2011 Chevy...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
