gc2300
   / gc2300 #1
earndale
oswego new york
mf gc2300
i have no hydraulics.. 6 years ago i replaced spur gear and pump.. now no hyds again i took apart and see nothing?? anything i can look for?
   / gc2300 #2
OK, a few questions.
If it is complete loss of all hydraulics, movement and FEL/3pt, check driveshaft connection to HST.
1. Hydro oil level ok?
2. Sudden loss or gradual?
3. Was unit operating when the hydraulics were lost.
4. Condition of gear teeth inside HST (assuming spur gear and pump are ok)
5.Suction filter clean?
6.Any leaks or collapsed hoses between the suction filter and pump?
7. FEL?
Further reading:
https://www.tractorbynet.com/forums/massey-ferguson-owning-operating/337459-gc2310-fel-very-weak-5.html
   / gc2300
hyd level ok lost hydraulics first then hydrostatic after, was using it when it went, gears look ok, suction filter good shape, no collapse hoses, when I pulled gear cover off a ball bearing fell out?? all bearings look good? pump looks ok spur gear looks ok?
   / gc2300 #4
Most likely internal failure in the pump. From what I've read, the valve assembly on top prioritizes flow to the hydro 1st, steering 2nd, then FEL/3pt last. If the pump begins to lose pressure, the FEL/3pt operation will be affected first. No idea what the ball bearing is from, but every pump failure/removal I've read mentions it falling out.
How many hours on tractor, hydro fluid? What brand of fluid are you using?
   / gc2300 #5
The hydraulics are hooked in series. I believe the flow goes from the pump to loader to three point. I assume your hydro is working if you can still drive it and the PTO works. If so then the pump is probably OK. If that is true than probably your issue is a faulty quick coupler between the loader valve and the loader.
   / gc2300
no hydro either??? one thing I did try before dismantling was I had pump out turn drive shaft and spur gear were pump goes in does not turn??
   / gc2300 #8
The pump shaft does not turn? If the pump does not turn when disconnected completely, pretty good indication that it is seized up.
You should not be able to turn the gear inside the hydro, it is connected to the transmission/engine.
   / gc2300
i turn drive shaft input and gear does not turn,,,spur gear that is i had pump out... i found were ball goes it goes 4wd lever on side it has a outside plug and a spring..
still no hydraulics??
   / gc2300
found were ball goes ...on right side 4wd lever has out side access port take nut out and spring behind it were ball goes..
also found hydraulic problem ... hydraostatic shaft spline gone .. main drive shaft connects to it then on back side to transmission
spline shaft hangs out spline is wore and spur gear wore going take apart this weekend
6-Row Rolling Cultivator Narrow INOPERABLE/PARTS ONLY (A52128)
6-Row Rolling...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
Kubota SVL95-2S...
