Jimc295
Bronze Member
Has anyone had an issue with their GC1700 series tractor 3pt leaking down fairly quickly? If so what was the fix? Thanks in advance.
When I working with the loader and am using ballast it will leak down periodically and I have to keep lifting it back up or it will drag. Say over the period of an hour or 2.What do you consider "faily quickly"? 3 points will bleed down over time, especially with a heavy attachment, like a box blade.
If it happens within a few minutes or when the tractor is running, you probably have a bad seal or two.
If it happens when the tractor is off, over a longer period (like an hour), and is just dropping a few inches, it's normal.
2010 gc2400 here.
it drops over time.
light (the trailer hitch) drops an inch every 2 hours even running.
the 400lb+ box blade, tiller,snowblower bleeds down faster. not worth sinking money into to correct that. slap the up lever every few minutes and good to go.
you can correct that, its a rabbit hole not worth the money to jump into. it involves a **** load of work and parts.
As others have stated, if you could literally see it drifting down, yeh it's a problem. Otherwise it's probably fine.Has anyone had an issue with their GC1700 series tractor 3pt leaking down fairly quickly? If so what was the fix? Thanks in advance.
