Dirt Moving GC1700 Series and a Single Bottom Mold Board Plow
   / GC1700 Series and a Single Bottom Mold Board Plow #1
jlgurr
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
Anyone with a GC 1700 series using a single bottom "turning plow" successfully? I have an opportunity to purchase one but was cautioned that our SCUTs may not be tall enough for such an attachment.
Thanks,
Jeff
   / GC1700 Series and a Single Bottom Mold Board Plow #2
Most implements need to be designed for a subcompact, or modified, to work well. But, some report being able to use standard implements, as is.
If all else fails, more lift could be accomplished by making the arms longer, so it may not be a big deal.
If you buy a category 0 sleeve hitch, you can get an old Brinley sleeve hitch plow, used. They are made garden tractors, so it will work fine.
   / GC1700 Series and a Single Bottom Mold Board Plow #3
Another possibility is to add an inexpensive 3pt quick hitch . . . As they also lengthen the arms reach too. I would think the gc1700s would be pretty good for most implements because their rise height and wheel clearance is better than some other scuts.
Can you stage the plow on some concrete blocks to tape measure height clearance needs ?
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2020 Gehl RT105 Skidloader (RIDE AND DRIVE) (A50774)
2020 Gehl RT105...
2000 International 4700 Truck (RUNS) (TITLE) (A50774)
2000 International...
CFG Industrial Q.A Hydraulic Breaker (A50121)
CFG Industrial Q.A...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Chevrolet...
