Buying Advice GC1700 for landscaping/yard work
   / GC1700 for landscaping/yard work #21
RE: Box Blade ~ I was a little worried about lack of power for pulling things like that. I haven't really seen any good explanatory videos on YouTube; most of the time it's just a guy pulling one around and I'm not really sure what's happening. Do you just kind of drag it around the yard? Do I have to remove the sod first? I was thinking of using the front loader to scrape up the sod, and then maybe a box blade to do the actual leveling.
The large rear wheels on tractors provide great mechanical advantage for PULLING. In addition, tractors are geared down for PULLING, in lieu of over-the-road speed.
Everyone's conditions are specific so it is difficult to generalize. That said, you generally want bare dirt or 'scalped' turf when starting with a Box Blade and a light tractor. A heavy tractor pulling a heavy Box Blade can cut through turf. A Box Blade takes a while to learn how to use well. It is an intermediate skill implement.
The cutting ability of a Box Blade is mostly related to its weight; specifically weight per foot of width. Effective cutting begins at 100 pounds per foot of width; 125 pounds per foot is better. Adjusting the Three Point Hitch 'Top Link' also effects cutting, but to a lesser degree. "Just right" soil moisture can make a big difference in marginal conditions.
You probably will not find using the bucket to remove sod satisfactory.
   / GC1700 for landscaping/yard work #22
You have expressed both desire and doubt for a $5,000 Backhoe.
Exactly what tasks do you contemplate for this attachment?
TBN surveys indicate that average annual use for residential tractors is eighty hours, with mowing being the primary task.
On a tractor the primary focus is on the Three Point Hitch and its Power Take Off (3-Pt/PTO). Secondary focus is on the Front End Loader (FEL). Trailing tertiary focus in on the rear/center drawbar.
MOWER LINK: finish mower vs mid mount mower - Google Search
   / GC1700 for landscaping/yard work #23
Thanks for the information! My lawn is tree/stump free, so no problems there. It's just overgrown with tall weeds, and the terrain is very uneven. My riding lawnmover gets stuck all the time because there are steep bumps and ruts. For example, when they ran power underground to the house, they dug out a trench all the way to the road. When they filled it back in, either they didn't bother grading it, or it sunk in. Along this large ditch, there's a long mound that also goes to the road. Same idea where they ran power/pipes to the well, there's just a big ditch from the house to it.
Besides that, the yard is just very uneven in general. The old riding mower was constantly hitting the dirt with the mower blade because of this, or getting stuck when I come up to a steep mound.
This is Box Blade or Rear/Angle Blade work for sure.
LINK: Google Box Blade vs Rear Blade
I have a long drainage ditch that goes the entire length of my yard, and it hasn't been maintained. When I bought the property a year ago, the yard was flooding because it had essentially collapsed or filled with debris/weeds. I dug parts of it out by hand to get the water moving, but it really wasn't wide enough. So definitely that.
I'm also planning to put in some trees and a fence. I figured I could use the backhoe to do this, even though I could get a post hole digger instead.
Also considering a small pond in the future, but that's low priority. Just a small one for koi or something.
I've got a lot of landscaping tasks planned, and I assume it'd be useful, but I developed some sticker shock after seeing the price jump up by ~33% for it.
   / GC1700 for landscaping/yard work #26
RE: Backhoe ~ I have a long drainage ditch that goes the entire length of my yard, and it hasn't been maintained. When I bought the property a year ago, the yard was flooding because it had essentially collapsed or filled with debris/weeds. I dug parts of it out by hand to get the water moving, but it really wasn't wide enough.
I'm also planning to put in some trees and a fence. I figured I could use the backhoe to do this, even though I could get a post hole digger instead. ~~ Photo 1, Photo 2.
I've got a lot of landscaping tasks planned, anda small pond in the future.
You can clear that ditch with a $300 Middle Buster. Break the debris with Middle Buster, scoop out with FEL. To plant a few trees you can loosen the ground in an 'X' pattern with a Middle Buster, then hand spade loose spoil. If you buy a heavier tractor with a heavier bucket, a Bucket Spade is at least as good as a Backhoe for planting trees. Stab, lift, go.
VIDEO: tractor middle buster - YouTube
An alternative for the same ditch clearing task is a Ratchet Rake bucket attachment. See Photos #3-#5. Pull out the debris with the rake, operating the tractor in reverse. Simultaneously, grade ditch banks. RATCHET RAKE IS WORTHLESS FOR DIGGING.
VIDEO: ratchet rake brush clearing - YouTube
You can buy a RR from the T-B-N store, button at top of this page.
Note: Multiple attachments stored on one, mobile, platform dolly. Photo #6.
With a Piranha Tooth Bar you can dig that pond. There are numerous tooth bars out there. The Piranha brand is highly regarded by light tractor users for excavation tasks. Ratchet Rake is superior for grading.
FEL will be your primary landscaping tool.
LINK: BXpanded Piranha Tooth Bar
Forget the Backhoe. Apply $5,000 toward a heavier tractor.
You can clear that ditch with a $300 Middle Buster. Break the debris with Middle Buster, scoop out with FEL. To plant a few trees you can loosen the ground in an 'X' pattern with a Middle Buster, then hand spade loose spoil. If you buy a heavier tractor with a heavier bucket, a Bucket Spade is at least as good as a Backhoe for planting tree. Stab, lift, go.
An alternative for the same ditch clearing task is a Ratchet Rake bucket attachment. Ratchet Rake is also good for light grading. WORTHLESS FOR DIGGING. See Photos 3-5.
Wow, thanks for all that. I wasn't familiar with middle busters.
   / GC1700 for landscaping/yard work #28
The universe of T-B-N contributors knows EVERYTHING.
   / GC1700 for landscaping/yard work #29
For me the biggest thing (and I am still quite a newbie) was looking at several different colors of tractor. They all make something in the size you are looking at. I'd also consider the dealer network near you. My nearest MF dealer is 30 miles away. I have Kuboda, JD and NH within 10 miles. So easier to get to for parts and service.
I have a few things the backhoe would probably be nice for, but could not justify the cost. I'll rent one or hire out if those projects come to fruition.
   / GC1700 for landscaping/yard work #30
The GC will do everything you want, just takes a while. The cost of the backhoe is almost equivalent to a box blade, rear snowblower and tiller combined. Box blade will not work well in a lot of sod. Tilling the sod off the top helps a lot. Trying to scrape the sod off with the loader is time consuming, and the sod clumps never grade well with the box blade. Contour the ditches into swales, much easier to mow, and less likely to get stuck.
Landscaping is a long term project, You'll never get it perfect quickly. I prefer to grade in spring and fall when the grass seed germinates quickly. If you find a spot where the mower scalps the lawn, re-contour it.
Scrape up some dirt to use as fill, it comes in handy.
Start a small garden right away, just keep expanding it every year.
What type of tires? I would get turfs if I had to choose again.
Dennis
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
