Buying Advice GC1700 for landscaping/yard work
   / GC1700 for landscaping/yard work #1
srpape
Ithaca, NY
N/A
Hi all,
Brand new poster, here, though I've been reading for a few days.
I'm considering buying a MF GC1700 series tractor soon. The prices seem to be better than the similar competitors I've been comparing against, and I only ever hear good things about them.
I have 4.8 acres of land, and it's more of a field than a yard. It's very uneven, there are long ditches where they ran power but didn't bother to fill in, mounds I'd like to take down, holes to fill in, etc.
My goals are:
  • Be able to mow the property in a reasonable amount of time (Looking at the 60" deck)
  • Do some rough grading so that I can mow easily
  • Dig out some drainage ditches that have deteriorated
  • Move snow in the winter
  • Be able to till a fairly small vegetable garden (eventually)
  • Plant some trees/fence posts
  • General landscaping
It sounds like the GC1700 series will do what I need (I'm fine with doing small sections at a time). I'm trying to decide if I really need that backhoe, though, since it'll add somewhere around $5,000 to the cost. I'm also trying to decide if the GC1720 is worth the extra $1500 or so, for extra 2.5HP and a nicer seat, but it sounds like that's more preference than necessity.
If anyone has any general recommendations on how I'd go about grading the yard, I'd love to hear. It sounds like maybe just dragging around a box blade will work? Or I'd have to rototill first?
Since I was getting landscaping estimates of around $7-10k per acre, it seemed more worthwhile to buy a SCUT. :)
Thanks for any advice!
-Stephen
   / GC1700 for landscaping/yard work #2
I'd rather do the work you are describing with the next sized up machine, like the 1726 ... a Backhoe would always be nice, but if you don't have specific needs already planned for it, then it might be $5k you don't need to spend, and instead rent a mini-x if/when you need one.
The reason I would go with the next size up is for clearance and traction out in the fields, doing "grading" work.
   / GC1700 for landscaping/yard work #3
Bigger is always better, and time is money. However the GC series can do everything you need done, just takes longer. I would never go without a backhoe, there that handy. Can't comment on the hp difference but it's the same engine, so the difference is fueling in the injection pump.
Drive both the GC series and 1700 series, either way you can't go wrong.
Thanks, I don't expect it to be a quick project, just a little here and there until it's done.
Any suggestions on implements I'd need to get started with some grading ? A lot of the videos I see have a huge tractor pulling some huge implement that I'm not sure I'd be able to handle.
Thanks for the advice.I do have some specific needs for a backhoe, but I don't know if I will once I've had it for a couple of years. I guess it can always come in handy. Originally I thought I'd get the 1705, and possibly add a backhoe down the road, but then I learned that you can't just add it on later.
Looking at the 1726E... doesn't seem like you can add a backhoe from the dealer. Also, adding a front loader to it puts it up around almost the same price as the GC1720, which has the backhoe already. More is always better, but I'm trying to keep the cost down somewhat.. I'm willing to spend more time to spend less money, as long I'm not way off base with my expectations of the GC1700s.
   / GC1700 for landscaping/yard work #6
Srpape . . Welcome to tbn.
I really like my gc1715. I considered the backhoe desire vs. need myself and I just didn't have the justification to store it more than use it because my trenching needs were done.
What I'm not clear on is your land contour and condition. As an example . . is your land full of small trees and deep farm ruts ? If so some will talk about brush hogging the property and then using a backhoe to pull stumps and then start leveling. But an alternate choice is to hire a guy with a good sized cat and in one action he can tear out the trees while rough leveling. This option is cheaper in cost and then you can use your tractor to ick up and transpirt all the small trees with rot ball to a pile and burn. But you don't need a backhie or hogging because the ground is quickly leveled and cleared and then your time is spent on eorking the areas to finish grades etc..
For me the difference of a gc1705 vs gc1715 was 1200.00 and that gave me a better seat, armored tail lighrs and 2.5 hp . . and those items increased my future benefits so I was glad I chose as I did. Recognize more hp is true for fel, for post hole digger or tiller needs or mmm.
Warranty is long and the unit is solid built and sure footed. Massey offers a hand full of finance options at good rates and their insurance option is very attractive. There are 4 mmm options (mine is the true mulcher) so you have numerous choices. And lets not forget a little larger seating platform for coats and boots and leg comfort and a front flow engine cooling method.
   / GC1700 for landscaping/yard work #7
A BoxBlade can be quite handy and there are plenty of videos out there of them being used. Axel and the others make good points. I pull a 5' BoxBlade around with a 24 hp tractor with R4 tires, and their not loaded with no problems.
   / GC1700 for landscaping/yard work #8
And another thing helpful in the op's statements is this is a "no rush" effort. I know 2 people who bought bigger tractors because of a couple upfront needs and then it sat and sat because a smaller tractor could handle all the othet activities easier and more conveniently.
Sounds like the op could really make the project a nice one . . especially if for less than 1000.00 he could get a cat to do all the early big effort. 1 day or so is all it should take unless the contour is really bad or there are big trees to clear.
   / GC1700 for landscaping/yard work #9
  • Be able to mow the property in a reasonable amount of time (Looking at the 60" deck) Advantage GC 1700, no belly mower for 1700E series You would have to pull a finishing mower.
  • Do some rough grading so that I can mow easily Advantage 1700E series, it's heavier, more powerful, and more stable machine
  • Dig out some drainage ditches that have deteriorated Advantage 1700E series, it's heavier, more powerful, and more stable machine
  • Move snow in the winter Advantage 1700E series, it's heavier, more powerful, and more stable machine
  • Be able to till a fairly small vegetable garden (eventually) Advantage GC 1700, in a small garden, I think the sub compact would shine
  • Plant some trees/fence posts Advantage 1700E series, it's heavier, more powerful, and more stable machine
  • General landscaping Advantage 1700E series, it's heavier, more powerful, and more stable machine
General thoughts on the list you posted (I'm a novice with limited tractor experience but the opinions are free)
Thanks for the information! My lawn is tree/stump free, so no problems there. It's just overgrown with tall weeds, and the terrain is very uneven. My riding lawnmover gets stuck all the time because there are steep bumps and ruts. For example, when they ran power underground to the house, they dug out a trench all the way to the road. When they filled it back in, either they didn't bother grading it, or it sunk in. Along this large ditch, there's a long mound that also goes to the road. Same idea where they ran power/pipes to the well, there's just a big ditch from the house to it.
Besides that, the yard is just very uneven in general. The old riding mower was constantly hitting the dirt with the mower blade because of this, or getting stuck when I come up to a steep mound. There are also rocks everywhere that I'd like to reduce.
I'm not looking for golf-course quality here; I want it graded enough to be able to mow it easily, and to avoid smashing the mower deck on every rock in the lawn.
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
Lot (3) HD 12' Corral Panels (A50515)
Lot (3) HD 12'...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
Cub Cadet GT2550 Riding Mower (A50515)
Cub Cadet GT2550...
